Alt 15.04.2010, 00:12   #5
this is for the M60 engine, should be same for the M62
Measuring:
disconnect sensor harness connectors
Coil resistance (approx.) @ 20 Degree C 540 +/- 10% Ohm
Air gap (sensor distance from toothed wheel 1.0 =/- 0.3 mm
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.daytona-sensors.com/tech_sensors.html
This is for the M30
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) CPS M30 picture by shogun_bucket - Photobucket
Disconnect plug. Measure between pins 1 and 2 the resistsnce, what1 is, see the drawing in link, the plug has a certain shape, so you cannot mix 1 and 3,
Specification: 520 Ohm plus/minus 5%
Check shielding: between 1 and 3 100 kOhm
Between pins 2 and 3 100 kOhm
repair throttle valve -resistance between pin 6+8 Erich E32: Tipps & Tricks 8 06.08.2006 13:27
Alle Zeitangaben in WEZ +1. Es ist jetzt 23:05 Uhr.
