| BMW 7er, Modell E38 |  |  |
| Varianten |
| Detail-Infos |
| Interaktiv |
 |    - Anzeige -
		|  14.04.2010, 20:39 | #1 |
	| Cheya
Fahrzeug: E38-735i (12,97),E34-535i (92)
				 Resistance
    Does anybody know resistance between pins on camshaft position sensor and crankshaft position sensor of M62 engine?...Thanks |
		|  14.04.2010, 21:14 | #2 |
	| Erfahrenes Mitglied
Fahrzeug: 745i
 Er erkundigt sich nach den Widerstandswerten zwischen den Anschlusspins von Nockenwellensensor (camshaft) und Kurbelwellensensor (crankshaft). |
		|  14.04.2010, 23:39 | #3 |
	| Cheya
 Please sorry,I can`t speak German. |
		|  14.04.2010, 23:44 | #4 |
	| † 2023
Fahrzeug: E32, Velociped NL
					Zitat von andreas4  Er erkundigt sich nach den Widerstandswerten zwischen den Anschlusspins von Nockenwellensensor (camshaft) und Kurbelwellensensor (crankshaft). |  @Cheya
That´s only the translation...
Greetings
Knuffel |
		|  14.04.2010, 23:45 | #5 |
	| Erfahrenes Mitglied
Fahrzeug: E38 740 07/98 stag300 E32 735i ac schnitzer
 Jarane kakav problem imas?
				__________________mfG.Mirza
		|  15.04.2010, 01:12 | #6 |
	| Shogun
 this is for the M60 engine, should be same for the M62
Measuring:
disconnect  sensor harness connectors
Coil resistance (approx.) @ 20 Degree C 540 +/- 10% Ohm
Air gap (sensor distance from toothed wheel 1.0 =/- 0.3 mm
  http://www.daytona-sensors.com/tech_sensors.html
This is for the M30
  CPS M30 picture by shogun_bucket - Photobucket
Disconnect plug. Measure between pins 1 and 2 the resistsnce, what1 is, see the drawing in link, the plug has a certain shape, so you cannot mix 1 and 3,
Specification: 520 Ohm plus/minus 5%
Check shielding: between 1 and 3 100 kOhm
Between pins 2 and 3 100 kOhm |
		|  15.04.2010, 20:43 | #7 |
	| Cheya
					Zitat von mirza740  Jarane kakav problem imas? |  pozdrav !
Mislim da mi lazno prijavljuje gresku na CPS-u,pa pomislih sto ne bi sam sa instumentom izmerio vrednosti sensora. |
		|  15.04.2010, 20:46 | #8 |
	| Cheya
					Zitat von Erich  this is for the M60 engine, should be same for the M62
Measuring:
  Daytona Sensors LLC - Tech FAQ Crankshaft Position Sensors
This is for the M30
Between pins 2 and 3 100 kOhm |  Thanks for your effort: |
		 Linear-Darstellung |
	|  Forumregeln |
 HTML-Code ist aus. |  |  |  |
