14.04.2010, 19:39
Cheya
Fahrzeug: E38-735i (12,97),E34-535i (92)
Resistance
  Does anybody know resistance between pins on camshaft position sensor and crankshaft position sensor of M62 engine?...Thanks
14.04.2010, 20:14
Fahrzeug: 745i
Er erkundigt sich nach den Widerstandswerten zwischen den Anschlusspins von Nockenwellensensor (camshaft) und Kurbelwellensensor (crankshaft).
14.04.2010, 22:39
Cheya
Please sorry,I can`t speak German.
14.04.2010, 22:45
Fahrzeug: E38 740 07/98 stag300 E32 735i ac schnitzer
Jarane kakav problem imas?
mfG.Mirza
15.04.2010, 00:12
this is for the M60 engine, should be same for the M62
Measuring:
disconnect sensor harness connectors
Coil resistance (approx.) @ 20 Degree C 540 +/- 10% Ohm
Air gap (sensor distance from toothed wheel 1.0 =/- 0.3 mm
http://www.daytona-sensors.com/tech_sensors.html
This is for the M30
CPS M30 picture by shogun_bucket - Photobucket
Disconnect plug. Measure between pins 1 and 2 the resistsnce, what1 is, see the drawing in link, the plug has a certain shape, so you cannot mix 1 and 3,
Specification: 520 Ohm plus/minus 5%
Check shielding: between 1 and 3 100 kOhm
Between pins 2 and 3 100 kOhm
15.04.2010, 19:46
Cheya
Measuring:
Daytona Sensors LLC - Tech FAQ Crankshaft Position Sensors
This is for the M30
Thanks for your effort:
15.04.2010, 19:43
Cheya
pozdrav !
Mislim da mi lazno prijavljuje gresku na CPS-u,pa pomislih sto ne bi sam sa instumentom izmerio vrednosti sensora.
14.04.2010, 22:44
† 2023
Fahrzeug: E32, Velociped NL
@Cheya
That´s only the translation...
Greetings
Knuffel
