Zurück   BMW 7er-Forum > BMW 7er Modelle > BMW 7er, Modell E38 > E38: Tipps & Tricks
Alt 09.12.2008, 19:50
Schaltwippen und FL lenkrad umbau am meiner VFL.
Benutzerbild von KawaBmw7
KawaBmw7
BMW C650 GT
Druckbare Version zeigen Jemanden per E-Mail auf dieses Thema hinweisen
KawaBmw7 KawaBmw7 ist offline 09.12.2008, 19:50
Bewertung: (1 votes - 5,00 average)
Ich hoffe es ist kein problem wenn ich es im englisch schreibe.
After I'd seen the topics here with the paddle shift steering wheel from E46 M3 I thought that's my next mod.
But the problem was that the M3 steering wheel doesn't fit on a pre facelift car.
So I decided to try something new and bought shift paddles from a Mercedes AMG and an old M-steering wheel to try to get them on it.
Here is the result.
Then I was thinking that you need 2 free contacts on the slip ring from a heated steering wheel for the shift paddles to work. As the pre facelift slip ring doesn't have these 2 contacts I decided to change my slip ring to one from a facelift car. Went to the junk yard and bought the complete steering column and tried to get it work on my pre facelift car.
Here the pre facelift steering column.
All clear.
Need to change some wires of wipers and turn signal.
The facelift steering column.
And the slip ring from heated steering wheel.
Testing with the steering wheel from Edwin.
Then the steering wheel with the shift paddles.
Made the connection for the shift paddles.
Then I used 3 ignition switches to make one good one so that I could keep my own key.
From 2 ignition switches I cut of the steel ring and from the third I cut the back so the steel ring keeps good.
The switches from pre facelift and facelift are in several ways different.
The small plates are both the same so I placed the ones from my original ingintion switch in the one from the facelift.
My own key in a facelift ignition switch.
The steel ring back in place and the switch is ready.
Next step was changing the LCM (light control modul), the LCM from the facelift is different. Turn signal in a pre facelift runs over 2 wires to the LCM, in a facelift it goes over 1 wire and it is in a different place on the LCM. Same is voor high beam, so I changed the pins to the right place and it all works fine now. I even have ‘follow me home’ now.
Some pics of the final result.
The video on Youtube.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) YouTube - E38 M-steering wheel with shift paddles
Hits: 32330
Mit Zitat antworten
Alt 22.11.2017, 14:17   #11
Captain_Slow
Lernfähiges Mitglied
Benutzerbild von Captain_Slow
Fahrzeug: C6, R1200RT
Leider sind hier keine Bilder mehr zu sehen - wie gross ist denn der Aufwand von VFL auf FL Lenkrad um zu bauen ? Muss da die Lenksäule auch getauscht werden ?
Alt 22.11.2017, 14:55   #12
juelz
█юЮ∏ξДღÞ₪ஆקƸ̵̡Ӝ̵̨̄Ʒ│ │█║▌│
Benutzerbild von juelz
Fahrzeug: E38 740iA (08.99) Sonderablauf Dienstfahrzeug
ich gehe mal davon aus, dass du dann das Airbagsteuergerät tauschen musst, weil ich nicht glaube, dass das aus dem VFL den 2-stufigen Airbag aus dem FL ansteuern kannst. Ebenso weiß ich nicht ob sich das nicht wie ein Rattenschwanz durch das Fahrzeug zieht.
Eigtl ist es egal, da dann immer beide Airbags gezündet werden. Aber die Rennleitung sagt was anderes... Ich versuche nun schon 1 Jahr lang einen bestimmten User zu erreichen, da dieser angeblich eine Freigabe von BMW für das M-Lenkrad aus E46 / E39 hat für den E38 hat (hier gehts aber um FL an FL)
Geht es dir um die Schaltwippen oder FL Lenkrad ? Schaltwippen gehen ja auch an dem VFL. Da ist nur der Schleifring interessant, wegen den freien Plätzen der Lenkradheizung...
wegen den Bilder, folge einfach dem E39 Foren Link, da sind die noch drin. (eine Seite zurück)
"Musik drückt aus was nicht gesagt werden kann und worüber zu schweigen unmöglich ist" Victor Hugo
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Foto Story (7,- € pro Klick)
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Foto Story (5,-€ pro Klick)
juelz ist offline   Antwort Mit Zitat antworten
Alt 22.11.2017, 19:33   #13
Captain_Slow
Mir ist zufällig ein FL Lenkrad in den Händen gekommen das wie neu ist, aber ich habe schon befürchtet, dass es zu viel Aufwand ist.
Alt 19.12.2018, 02:42   #14
akay
Benutzerbild von akay
Fahrzeug: E38 740i (04/98)
Standard Schaltwippen VFL
Habe den Thread gerade erst gefunden.
Umbau auf Schaltwippen finde ich Super, da ich schon öfters das Steptronic benutze um selber zu Schalten.
Aber,.....Geht es nun mit einem VFL M-Lenkrad und einem VFL Schleifring mit Lenkradheizung? Oder eben nur mit FL Schleifring und Lenkrad.
Hab einen 740i VFL aus 04/98.
Weiss jemand das nun genau?
Danke,
Mfg
akay ist offline   Antwort Mit Zitat antworten
Lenkung: VFL Lenkrad wieder einbauen NickB12 BMW 7er, Modell E38 1 15.05.2008 12:22
Lenkung: M3 CSL Lenkrad mit schaltwippen einbauen ??? omon007 BMW 7er, Modell E38 17 09.12.2007 17:54
Lenkrad Leder/Holz Vfl Nightcrawler Suche... 4 20.03.2007 21:05
Elektrik: Schalter Zentralverriegelung VFL umbau auf FL BMWe38 BMW 7er, Modell E38 3 28.09.2006 19:53
Innenraum: Navi Umbau und M Lenkrad Inspectorerkan BMW 7er, Modell E38 3 06.01.2005 22:22
Alle Zeitangaben in WEZ +2. Es ist jetzt 04:51 Uhr.
