Alt 06.08.2010, 17:18   #1
Glacier
Benutzerbild von Glacier
Fahrzeug: E38 - 740i (02/2000)
Hi, yes, I think you are reffering to the PCV valve, No.2:
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) RealOEM.com BMW E38 740i Intake manifold system
This was replaced about 2 years ago, so not a likely candidate I would have thought. Also, I think you would have got smoke and a wheezing noise if that had gone.
I have put in 8 new coils and spark plugs and 2 aftercat O2 sensors.
I did the repair myself and the timing was 'by the book'.
If you are asking about the price of parts:
2 VANOS units = £250 each.
2 check valves = £10 each.
Valve & upper timing chain gaskets = £50
Timing tools = £300.
Expensive?.............yes!
But worth it just to get shut of that embarrassing noise.
Still no fault codes!
Anymore ideas?
Thanks.
Glacier ist offline   Antwort Mit Zitat antworten
Alt 06.08.2010, 17:45   #2
memyselfundich
Langstrecken Gleiter
do you have access to a "INPA" enpowered laptop?
if yes, then you could try the "Unruhemessung" Not sure how it´s called in english - It´s the Measurement you can start to see which cylinder is running not a smooth as the others. The Coil´s *can* bei DOA, are they aftermarket or OEM Bmw?
Switching of the After cat sensors is usually not needed - but the BEFORE cat sensors are quite important.
While you are already busy spending money - switch the "LMM" Air Mass measurement things in front of the throttlevalve - which you can also switch out while you are at it Then change the Valve cover gaskets, and your engine will pur as new
Alt 06.08.2010, 18:16   #3
Glacier
I think you mean 'synchronized' cylinders.
No INPA laptop I'm afraid. Surely BMW DIS would have found something like incorrect timing in the cylinders?
The coils were OEM BMW.
Yes the 'before' cat sensors are important as you say but, I think there would be a fault code if one was broken.
New valve cover gaskets went on.
Again, if the MAF was suspect I would expect a fault code.
But there aren't any : No
Thanks for your input.
Alt 06.08.2010, 18:48   #4
memyselfundich
you don´t need a fault code for the component for not working as fast / accurate as it could. Might not be enough to pass the threshold for the error to be logged, but still might cause erratic problems... I drove around with that defect coil, and was getting really annoyed with the lumpy ride - and I didn´t have any fault codes either. I just switched the Spark plugs from ngk to bosch and thought the spark plugs where crappy...
What gaskets haven´t you switched yet? Air intake gaskets? Have you resetted the adaption stuff, and driven for 30 or so miles?
Alt 06.08.2010, 19:27   #5
McTube
Benutzerbild von McTube
Fahrzeug: S50B32
Do not ever overestimate diagnostics. There is a bunch of things it will not see, but an experienced mechanic will....so I agree with the above answers.
Alt 08.08.2010, 14:18   #6
Glacier
Yes, you are probably right.
The air intake manifold gaskets were done at the same time as the PCV valve, and I checked for vacuum leaks by spraying brake cleaner all around the engine to see if there was a change in the idle........nothing.
When I tried to reset the adaptions there was a message saying "Module not responding". Even so, I have driven about 300 miles since the re-timing so I would have thought the DME would have learned the adaptions by now.
I wonder if there is a burnt valve or something?
Oh well, I'll keep trying to find what's wrong and will report back if I find anything.
Many thanks again for all your suggestions.
Alt 17.03.2011, 17:04   #7
macgyver52
Stan
Fahrzeug: F01-750i (06.09)
Hi Glacier,
it looks like i have the same problem with my 740i.
It also has the startup rattle, but i try to ignore it until it gets worse.
The more annoying problem is the vibrating engine in the same rpm range.
Do you or anyone have a solution by now?
I checked nearly everything, but i can´t find the reason.
macgyver52 ist offline   Antwort Mit Zitat antworten
Alt 19.03.2011, 11:15   #8
Glacier
Hi Stan,
not sure but, I think the startup rattle is caused by the oil draining from the vanos units, No.1:
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) RealOEM.com BMW E38 740i timing gear timing chain top - VANOS
When I changed the the two units I also changed the oil check valves, No.8:
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) RealOEM.com BMW E38 740i Cylinder Head Attached Parts
So, I'm not sure if it was the check valves, vanos units or a combination of both that cured the startup rattle. The vanos units change certainly fixed the ticking/tapping diesel-like noise
I did as 'Memyselfundich' suggested and got myself INPA. Here are some live data pictures of the cylinders:
I'm not sure what all that means so, maybe some of you German experts could confirm that they don't look too bad. Or do they seem not to be very well synchronized?
Now.......... I have been doing more investigating and I found that these parts on the nearside rear wheel have some play in them, No.2 & 5:
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) RealOEM.com BMW E38 740i REAR AXLE SUPPORT/WHEEL SUSPENSION
When the wheel is rocked at 12 & 6 o'clock there is about 1/4 inch movement. Nothing at 3 & 9 o'clock.
So, I have come to the conclusion that maybe I have been looking in the wrong place all the time! Most probably I did time the engine correctly and, by a crazy coincidence at that exact time, the rear balljoint started to make the car feel lumpy? And that's why I wasn't getting any fault codes from the engine.
Of course this is all guesswork until I have changed the offending parts. I may as well change the other rear bits too and I have got the parts from good old Ebay-de:
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) REP SATZ QUERLENKER_HA 7ER E38 KOMPLETT 10-TEILIG NEU! on eBay (end time 14-Mar-11 13:00:40 GMT)
Waiting for this:
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Advanced Keyword Product Search --- Sealey & Draper Tools - CCW-Tools
More expense!
I will report back on my findings.
Vanos im 735 740? Rainer H BMW 7er, Modell E38 8 02.12.2011 20:24
General question + noise -> in the trunk Maarten730 BMW 7er, Modell E32 7 05.04.2009 17:41
Motorraum: Vanos ? andromedar2000 BMW 7er, Modell E38 6 15.04.2007 21:37
VANOS o. Doppel-VANOS EXPERTEN gesucht JB740 BMW 7er, Modell E38 19 01.04.2006 19:57
730d turbo(?) noise and lack of power Rik Gruwez BMW 7er, Modell E38 3 11.01.2003 11:31
Alle Zeitangaben in WEZ +1. Es ist jetzt 22:38 Uhr.
