Alt 06.08.2010, 15:28   #1
Glacier
Benutzerbild von Glacier
Fahrzeug: E38 - 740i (02/2000)
Top! VANOS noise fixed.......but another problem.
2000 E38 740i M62TU 04.04 101.000 MILES .
Hi, apologies for not speaking German .
I had the 'startup rattle 'and a noise the same as this video:
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) YouTube - ‪M62B35 Ticking‬‎
After a lot of research, I concluded that it was coming from the VANOS units.
The E38 M62TU engine should not sound like a diesel .......... right?
So, I bought two new units , No.1 :
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) RealOEM.com BMW E38 740i timing gear timing chain top - VANOS
And two new oil check valves , No.8 :
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) RealOEM.com BMW E38 740i Cylinder Head Attached Parts
Also the timing tools:
Here are the old VANOS units:
And the new VANOS units:
Now I am happy to report that the engine is nice and quiet, no more embarrassing tapping/knocking/diesel like noise. Also, no more startup rattle : Top
The problem is that the engine feels slightly ' lumpy '.
The idle is at 600 rpm and is steady. When the accelerator is pressed (car not moving) , there is a slight vibration up to 1200 rpm and then smooths out .
When driving along, at any speed, it feels like you are going over lots of ' bumps ', but the road is smooth.
I connected Carsoft V8.3 and there were no fault codes. I then took it to BMW for diagnostics ......... ........ same result no fault codes.
I tested for vacuum leaks ......... none .
Any ideas anyone?
Glacier ist offline   Antwort Mit Zitat antworten
Alt 06.08.2010, 16:41   #2
memyselfundich
Langstrecken Gleiter
lumpy Idle can be caused by the Crankshaft Ventilation thingy on the back of the Engine block. I had a fault ignition coil that caused a lumpy reving for weeks before it finally died and showed up on the Faultmeter. Sparkplugs and Lamdba´s also are possible candidates for causing a lumpy idle.
How much did you pay for the whole repair? How much milage does the car have?
Ups sorry, 101miles
Alt 06.08.2010, 17:18   #3
Glacier
Hi, yes, I think you are reffering to the PCV valve, No.2:
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) RealOEM.com BMW E38 740i Intake manifold system
This was replaced about 2 years ago, so not a likely candidate I would have thought. Also, I think you would have got smoke and a wheezing noise if that had gone.
I have put in 8 new coils and spark plugs and 2 aftercat O2 sensors.
I did the repair myself and the timing was 'by the book'.
If you are asking about the price of parts:
2 VANOS units = £250 each.
2 check valves = £10 each.
Valve & upper timing chain gaskets = £50
Timing tools = £300.
Expensive?.............yes!
But worth it just to get shut of that embarrassing noise.
Still no fault codes!
Anymore ideas?
Thanks.
Alt 06.08.2010, 17:45   #4
memyselfundich
do you have access to a "INPA" enpowered laptop?
if yes, then you could try the "Unruhemessung" Not sure how it´s called in english - It´s the Measurement you can start to see which cylinder is running not a smooth as the others. The Coil´s *can* bei DOA, are they aftermarket or OEM Bmw?
Switching of the After cat sensors is usually not needed - but the BEFORE cat sensors are quite important.
While you are already busy spending money - switch the "LMM" Air Mass measurement things in front of the throttlevalve - which you can also switch out while you are at it Then change the Valve cover gaskets, and your engine will pur as new
Alt 06.08.2010, 18:16   #5
Glacier
I think you mean 'synchronized' cylinders.
No INPA laptop I'm afraid. Surely BMW DIS would have found something like incorrect timing in the cylinders?
The coils were OEM BMW.
Yes the 'before' cat sensors are important as you say but, I think there would be a fault code if one was broken.
New valve cover gaskets went on.
Again, if the MAF was suspect I would expect a fault code.
But there aren't any : No
Thanks for your input.
Alt 06.08.2010, 18:48   #6
memyselfundich
you don´t need a fault code for the component for not working as fast / accurate as it could. Might not be enough to pass the threshold for the error to be logged, but still might cause erratic problems... I drove around with that defect coil, and was getting really annoyed with the lumpy ride - and I didn´t have any fault codes either. I just switched the Spark plugs from ngk to bosch and thought the spark plugs where crappy...
What gaskets haven´t you switched yet? Air intake gaskets? Have you resetted the adaption stuff, and driven for 30 or so miles?
Alt 06.08.2010, 19:27   #7
McTube
Benutzerbild von McTube
Fahrzeug: S50B32
Do not ever overestimate diagnostics. There is a bunch of things it will not see, but an experienced mechanic will....so I agree with the above answers.
Vanos im 735 740? Rainer H BMW 7er, Modell E38 8 02.12.2011 20:24
General question + noise -> in the trunk Maarten730 BMW 7er, Modell E32 7 05.04.2009 17:41
Motorraum: Vanos ? andromedar2000 BMW 7er, Modell E38 6 15.04.2007 21:37
VANOS o. Doppel-VANOS EXPERTEN gesucht JB740 BMW 7er, Modell E38 19 01.04.2006 19:57
730d turbo(?) noise and lack of power Rik Gruwez BMW 7er, Modell E38 3 11.01.2003 11:31
Alle Zeitangaben in WEZ +1. Es ist jetzt 23:30 Uhr.
