Alt 26.04.2005, 17:46   #1
Satjoh
Standard backlights mid-display E38 (voltage bulbs)
Don't know if I can post in english...................??
The mid-display (radio, clock) has become very dim. I took it out and found 12 small bulbs which light the display from behind. 4 of those had burned out and another 4 are "dark-blue" and very dim.
Can anybody tell me the voltage of those bulbs?
Alt 26.04.2005, 19:51   #2
eurojet
Benutzerbild von eurojet
Fahrzeug: E30 325i Cabrio M Technik 1, Audi A4 B6 Avant
Hi!
The voltage of this bulbs are already 12 Volt`s, I think!
I think you look for the watts. I found in the TIS bulbs for "Anzeigefeld LCD Modul" (it should be the MID), the are marked with 1,2W.
Regards
Eurojet
eurojet ist offline   Antwort Mit Zitat antworten
Alt 27.04.2005, 21:42   #3
Satjoh
Defenitely not 12 Volts.
I measured the voltage and came to approx 4 Volts.
Tried 6 volts bulbs but they were too dim.
Then tried 3,6 Volt bulbs (those very small ones with 2 little wires attached) and theu burn perfectly. Replaced all 12 bulbs (soldered them straight on) and my display is 100% bright. I am very happy!
E38 vs. E65... Chancenlos? Von wegen! Silver BMW 7er, allgemein 76 22.10.2020 16:29
MID für E38 John McClane Suche... 13 22.11.2004 19:32
Alle Zeitangaben in WEZ +1. Es ist jetzt 03:49 Uhr.
