Alt 22.04.2017, 07:40   #22
Bei Zuendung an gehen die Pumpen kurz an um Druck aufzubauen, ich hab die Beschreibung jetzt nur in Englisch von M1.1 und M1.3, ist aber das gleiche bei M1.2 und M1.7. Die Pumpen laufen auch noch 3 Sekunden weiter, wenn der Motor abgestellt wird, auch das um Druck zu halten zum naechsten Starten.:
Relays
The Motronic electrical system is controlled by a main fuel injection relay and a fuel pump relay. A permanent voltage supply is made to the main relay terminals 30 and 86 from the battery positive terminal. When the ignition is switched on, the ECU earths terminal 85 through ECU terminal number 36 which energises the first relay winding (on the 1987 M1.1 system, this connection was made directly to earth). This causes the first relay contacts to close and terminal 30 is connected to the output circuit at terminal 87. A voltage supply is thus output at terminal 87. Terminal 87 supplies voltage to the injectors, ECU terminal 37, ISCV and the CFSV when fitted. In addition voltage is supplied to the fuel pump relay terminal 86. When the ignition is switched on. the ECU briefly earths fuel pump relay contact 85 at ECU terminal 3. This energises the relay winding, which closes the relay contact and connects voltage from terminal 30 to terminal 87, thereby providing voltage to the fuel pump circuit. After approximately one second, the ECU opens the circuit and the pump stops. This brief running of the fuel pump allows pressure to build within the fuel pressure lines, and provides for an easier start. The fuel pump relay circuit will then remain open until the engine is cranked or run. Once the ECU receives a speed signal from the CAS, the relay winding will again be energised by the ECU, and the fuel pump will run until 3 seconds after the engine is stopped. The 3 seconds delay in switching off the pump relay allows the fuel pump to maintain pressure on engine shut-off to avoid engine run-on. In addition, on some vehicles control of the OS heater is made through a separate OS relay. Once the ignition is switched on, a voltage supply is made to the OS heater relay terminals 30 and 86. When the engine is started, the ECU connects relay terminal 85 to earth through ECU pin 23. The relay actuates and the output voltage at terminal 87 provides voltage to the OS heater. The ECU switches off the relay under certain conditions of speed and load.
Wenn Du jetzt neue Pumpen einbaust, halten die originalen Rueckschlagventile in den neuen Pumpen sicher erst mal 10 Jahre, spaeter kannste die ja dann einbauen, wenn notwendig.
Probleme mit Motorlauf beim M70 der andi BMW 7er, Modell E32 16 13.09.2012 07:23
Bmw 850 (750-m70) SV-777BY Autos allgemein 36 28.02.2011 22:13
Motorraum: Nochmals... Unrunder Motorlauf M70 Norwegian BMW 7er, Modell E32 22 22.11.2009 11:04
Motorraum: Unrunder Motorlauf im kalten Zustand 750 Brui1000 BMW 7er, Modell E38 12 16.10.2009 10:43
Motorlauf M70 christian 72 BMW 7er, Modell E32 22 11.11.2007 19:12
Alle Zeitangaben in WEZ +1. Es ist jetzt 11:38 Uhr.
