Alt 02.10.2004, 10:41   #1
th2376
Standard Problem with instrument/dashboard lights ..
Hello!
I really screwed up today. I hooked up new stereos and accidently connected wrong wires together. When I took a testdrive, I noticed that stereos worked just fine, but instument lights and dashboards lights not ..
So, I took the stereos off and noticed that I had accidently connected the wire that probably controls the dimming of lights to ground .. . I fixed my mistake right away, but the lights never came back. The position of dimmer switch does not matter. Therefore when driving the car, almost the whole dashboard is dark. Only lights that are still there are the kilometer/gear lights, and in the dashboard the small green lights located in the air conditioning panel auto buttons ...
I checked fuses, and they are all ok.
What do you think could have broken, where should I start locating the problem?
Ps. You can also answer in German, I understand it quite well!
Thank you,
Greetings from Finland,
Tuomas
Alt 02.10.2004, 14:53   #2
osl jaap
street-legal racer
Benutzerbild von osl jaap
Hi Tuomas,
When all the lights stay dark and your fuses are ok, my guess would be the dimmer switch. Perhaps its burnt up from the inside and doesnt connect anymore. Check it outside the car with an ohm meter. The km led's and the airco led's are not connected to the dimmer by my knowledge.
succes in resolving your problem.
Ciao,
Osl Jaap
Problem with steptronic? moriz202 BMW 7er, Modell E65/E66 5 14.02.2004 20:28
Oel-Analyse Erich BMW 7er, allgemein 2 09.02.2004 18:51
Navigation problem with dvd disc moriz202 BMW 7er, Modell E65/E66 2 12.01.2004 12:28
Mein Tagebuch --- morgen Nachsitzen für den BMW-Händler 735i BMW 7er, Modell E65/E66 3 14.05.2003 13:33
Several problems with '91 735IA Odegard BMW 7er, Modell E32 4 23.04.2003 17:27
Alle Zeitangaben in WEZ +1. Es ist jetzt 23:38 Uhr.
