Alt 15.03.2011, 14:58   #7
Kai, am Anfang geht die Visko bei kalten Motor voll und geht nach 2-3 Minuten dann runter.
Hier die beste Anleitung zum Testen, Auszug hier:
Testing the fan clutch:
If you have reason to suspect that the fan clutch is defective, here is the recommended procedure to verify the condition of the fan clutch.
1. Start the car (cold) with the hood open and note if the fan is turning, increase the engine RPM and note if the fan turns faster and the noise increases, if it does, first good indication, if it does not increase speed/noise, clutch is bad and needs to be replaced. (Remember, this must be tested after the car has been off for and extended period, over night etc.)
2. Leave engine running and note if the fan starts to slow down after 2-5 minutes, speed/noise should diminish and even raising the RPM, the fan should not make as much noise as when first starting, if it does slow, this is the second good indication. If speed/noise does not decrease, clutch may be “frozen” and should be replaced.
3. Leave the engine idle and watch the temperature indicator. When normal operating temperature has been reached, some increase in fan speed/noise should be noted, in particular when the RPM is increased. If temperature is fairly stable and the fan noise/speed increases or cycles, third good indication. If temperature indication continues to increase, with no increase in fan noise/speed, clutch is defective and should be replaced.
4. After the engine is at normal operating temperature or above, is the only time that the...
der Rest
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.mwrench.com/Whitepapers/FanClutchtest.pdf
Motorraum: Grrr..Viscolüfter ausbauen? wie?? und Tür bleibt zu!??! am besten V8 BMW 7er, Modell E38 17 04.05.2016 16:58
Elektrik: ZV Beifahrerseite keine Funktion und frage zu Viscolüfter E32Neuling BMW 7er, Modell E32 17 01.05.2007 18:12
Radio, Bordmonitor navi und alles andere auser funktion.und keine anzeige im kombi Micu BMW 7er, Modell E38 21 18.03.2007 12:43
Elektrik: Zusatzlüfter geht an und aus UBE BMW 7er, Modell E32 4 04.07.2005 11:54
Motorraum: ZusatzLüfter und Klima Guenni0501 BMW 7er, Modell E38 0 11.07.2004 23:41
Alle Zeitangaben in WEZ +1. Es ist jetzt 22:25 Uhr.
