Alt 09.05.2010, 14:37   #6
Interner Link) http://www.7-forum.com/forum/24/dros...-e32-5321.html
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.e38.org/e32/M70info.pdf
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.europeantransmissions.com...MW/EML-BMW.pdf
von Seite 52 Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www1.snapon.com/display/DocMg...px?fileid=4653
Bosch EML for M70 and S70 Engines
This is the first, full drive-by-wire electronic throttle system (used in U.S. only on the 7 and 8 Series). On the V12, a separate control module called EML synchronizes and controls dual throttle valve assemblies called DKs.
Whenever power has been disconnected or EML components have been replaced, the EML system usually requires adaptation to synchronize and coordinate system components. Use the following throttle synchronization procedure for the M70 engine.
z To synchronize the EML throttle:
1. Disconnect the battery for at least 1 hour.
2. Connect the battery and start the engine. Let the engine reach operating temperature without touching the accelerator pedal.
3. With the transmission in first gear, accelerate until engine speed is over 5000 RPM.
4. Release the accelerator pedal and coast until engine is at idle.
5. Repeat the above operation two consecutive times.
Auf jeden Fall die Drosselklappen saeubern
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.mwrench.com/Whitepapers/DKMotorcleanup.pdf
Geändert von Erich (09.05.2010 um 14:43 Uhr).
Innenraum: Ledersitze vom 750iL im E34 / Frage zur Sitzheizung Dennis_E34 BMW 7er, Modell E32 5 12.12.2005 16:26
mal ne frage zu heizung 750il Patrick P. BMW 7er, Modell E32 13 22.07.2004 11:03
Frage zu Getriebeausbau 750iL Patrick P. BMW 7er, Modell E32 0 10.09.2003 22:29
Frage zum 750il! KJ750IL BMW 7er, Modell E38 27 05.08.2003 10:50
Frage zu Automatik 750IL Patrick P. BMW 7er, Modell E32 6 26.06.2003 12:51
Alle Zeitangaben in WEZ +1. Es ist jetzt 22:24 Uhr.
