Alt 20.03.2024, 17:20   #1
andrewgrhogg
Fahrzeug: 2000 750iL
My car has EDC only and no leveling. Maybe this was an option in the US only.
Thanks for the links - very helpful. I did search but didn't find those - sometimes searching in english doesn't pull he right threads.
I will email the german company that someone mentioned (texerv) and see if they can refresh the shocks and for how much - and will of course report back.
And more - i messages Peter (heatingpad) about his Chinese dampers hat he has had for 3 years and he reported back that they are working very well still after about 12000km.
andrewgrhogg ist offline   Antwort Mit Zitat antworten
Alt 20.03.2024, 17:54   #2
gasi
um was gehts jetzt genau?
Benutzerbild von gasi
Well, if you know for sure it is OK.
However all I know is that leveling was an option for all models except for the long versions and for the 750's. These got it as standard equipment.
Leveling has no controls for the driver and it only affects the rear axle whereas the rear shocks have hoses conncted to them.
Mein Filmtipp:
Endlich dicht!
Alt 20.03.2024, 19:54   #3
Arvak
Fahrzeug: e31 850i ('91); e32 750iA ('91); e34 535i ('90); e36 328iA Cab.('98); e38 750i ('01); e39 540iA Touring ('01); e46 330iA Touring ('02); e61 530d ('07)
Hi Andrew,
I had some shocks overhauled from Texerv.
Worked just fine.
If there is a language barrier or other problems to connect, just let me know. I am happy to assist.
Regards from Northern Germany
Boje
Arvak ist offline   Antwort Mit Zitat antworten
Alt 21.03.2024, 16:22   #4
andrewgrhogg
I did reach out to Tim at Texerv - his written english is very good! Probably better than most Americans....tho that bar is not very high. Unfortunately all he works on is SLS shocks these days. So still stuck with options of Poland, and buy Chinese knock-offs. What to do?
And to just close the loop on the rear shocks - i took pics of the shock label and they are Sachs, part # 331700105197, which comes back as EDC only. RealOEM has the part number as 33521091573, but they appear to be the same shock.
Front left is Sachs 141500115440, whole Realoem shows 31311091557. But again appear to be the same shock.
Geändert von andrewgrhogg (21.03.2024 um 17:13 Uhr).
Alt 21.03.2024, 17:00   #5
Arvak
I have no personal experience with them - but heard positive results coming from the E31 community.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://brt-automotive.de/fahrwerksrevisionen/
Maybe worth a try?
Alt 21.03.2024, 17:16   #6
andrewgrhogg
Thanks - i have emailed them (brt automotive) with all the info about my car and current shocks to see if they are able to refurbish, and if so for what cost. Once i get an answer i will update for future interested people.
Alt 22.03.2024, 08:04   #7
Bruno0711
Fahrzeug: e38 740iA BJ1998; e39 528iA BJ1996
Updates would be nice. Sooner or later it will become relevant for everyone with EDC I guess..
Bruno0711 ist offline   Antwort Mit Zitat antworten
Alt 21.03.2024, 17:04   #8
gasi
Poland or Chinese knock-offs. What to do?
I clearly recommend to refurbish yours in Poland. So did I yeas ago with the Nagengast company. To me it would be too risky to go the chinese way.
Alt 29.03.2024, 16:32   #9
CM Heimann
Benutzerbild von CM Heimann
Fahrzeug: E38-750i (07.98), E46-323ci (12 99), F10-535i (09 11)
Idee Self leveling suspension 750i and L
As far as I know all 750s come with self leveling (Niveauregulierung) it would be quite a surprise if they would have specked "down" the US version. Normally it is specked up over there. Except for E60 M5 six speed manual, wich actually makes a lot of sense to me. @ Andrew, if you run into communication trouble feel free to contact me.
CM Heimann ist offline   Antwort Mit Zitat antworten
Luftfederung ION6 BMW 7er, Modell F01/F02 27 27.04.2023 09:50
Luftfederung arni111 BMW 7er, Modell E65/E66 2 12.04.2018 20:51
Who is making springs and shocks for e23 kaospiloten BMW 7er, Modell E23 4 26.09.2005 18:07
Luftfederung Haller BMW 7er, Modell E38 0 27.12.2002 20:46
Alle Zeitangaben in WEZ +1. Es ist jetzt 18:16 Uhr.
