Alt 01.04.2008, 22:09   #1
petoch
Fahrzeug: E32-730i (11.89)
Standard Electric and transmission
Please HELP me. I can not speak German, so I decided to write in English. Sorry.
My problem:
I bought E32 730i (11/1989). There was a problem with automatic transmission. When I am trying to move in D, it will start moving with 2nd gear. After 10 - 15 meters there is 1st gear and it is still there until 6000 rpm and then tha transmission gives me the 4th gear - so I can drive a little bit faster. So there is no 3rd gear. It will come to 2nd gear, when I am driving around 20km/h. It is always the same even when I am trying to start with position 1 or 2 or 3. (except the 4th gear of course). In BMW they told me, that everything electric (control unit of transmission) is OK and there must be mechanical problem in transmission. So I bought another transmission with a control unit from a guy, who drove the transmission on a car (E32 730i 1987) from Germany to Czech republic. I changed the transmission and control unit. After starting the engine there was GETRIEBE PROGRAM. In BMW they told me, that there was one control unit until 9/88 and another one after 9/88. So I connected the original control unit and it was the same. So IT IS NOT MECHANICAL PROBLEM. Then they told me, that I need another control unit. I found the same one as I need - AND IT IS THE SAME.
PLEASE, let me know, how to check the cables from transmission to control unit if they are OK, where are all the connectors that need to be cleaned and what kind of sensors on engine are cooperating with control unit of transmission. I AM DESPRED. I THINK THAT I CAN FIND HELP HERE WITH YOU!!! I TRIED ALMOST EVERYTHING.
THANK YOU FOR YOUR ANSWERS.
petoch ist offline   Antwort Mit Zitat antworten
Alt 01.04.2008, 22:34   #2
Contact "Fugo" = Jakub in Jablonec nad Nisou, you can talk to him in the same language and he is an expert on the E32.
Here you can send him an email or U2U private message
Interner Link) http://www.7-forum.com/forum/member.html?u=8338
checking the cables: see my website below, there is a link to europeantransmissions.
Test data are there.
Alt 02.04.2008, 06:25   #3
Fugo
Benutzerbild von Fugo
Fahrzeug: Ford Transit und Kawasaki ZX10R
Napiš mě česky nebo slovensky, anglicky ti nerozumím, nebo můžeš pohledat na bmwklub.cz
(Schreibst du mir tschechisch oder slowakisch, english verstehe ich nicht, oder kannst du auf bmwklub.cz finden)
MfG Fugo
Fugo ist offline   Antwort Mit Zitat antworten
Alt 02.04.2008, 17:02   #4
SALZPUCKEL
Ex M60-powerd by LPG
Benutzerbild von SALZPUCKEL
Hello
maybe that you have an defect in the "gear selector switch". Read here:
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Switch 1
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Switch 2
Best wishes
Wolfgang
PD 27-04-93
Das Leben geht weiter.
Alt 12.04.2008, 20:47   #5
petoch
Standard Everything is all right now!!
DE:
Danke FUGO fur deine elektrik scheme. Ich habe 8-pin getriebe und nur 7 kabel in das auto. Ich gibt 1 kabel mehr fur pin 2 das getriebe zu pin 20 an getriebesteuerung und alles ist OK. DANKE FUR DAINE HILFE!
EN:
Thank you FUGO for your electric scheme. I have 8-pin transmission, and there was only 7 cables connected to transmission. So I have connected one more cable from pin 2 on transmission to pin 20 on transmission control unit. THANK YOU FOR YOUR HELP!
Alt 13.04.2008, 03:57   #6
the solution
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://bmwe32.masscom.net/johan/gear...rbox_swap.html
you can adapt the gearbox to fit by transplanting the electronics from one box to another
Elektrik: electric troubleshooting manual Erich E32: Tipps & Tricks 3 13.02.2022 13:46
Motorraum: Transmission Fundamentals Erich 7er, allgemein: Tipps & Tricks 2 01.05.2009 17:45
Bremsen: Manual transmission braveheart BMW 7er, Modell E32 1 02.04.2006 22:16
I Need A Transmission For Bmw E32 braveheart Suche... 2 17.03.2006 20:08
Electric spinnt by meinem 740 wolf93 BMW 7er, Modell E38 4 21.03.2004 04:09
Alle Zeitangaben in WEZ +1. Es ist jetzt 05:46 Uhr.
