Alt 09.12.2007, 17:48   #1
Dutchman V12
Benutzerbild von Dutchman V12
Fahrzeug: BMW E32 750i 05-1993
Frage Kick-Down problem E32 V12 750i HOLLAND
Hello Deutche Freunden!
My name is Bart, i am from Holland (Tilburg) and my Deutch is not so good, so i try to ask you a question in Englisch. Sorry for that !!...
I own a BMW 7-series 750i E32 from modelyear 1993. I have a problem with the automatic gearbox and i hope you know what the problem is.
When i driver normal, nothing is wrong, the gearbox changes gears smoothly.
But when i hit the Kick-Down, the gearbox changes a gear down, wich i think is good, but when it reaches 5000/6000 RPM or so it does NOT shift UP untill i release the Kick-Down, then it chages the gear up correctly?!
Can someone help me please
Geändert von Dutchman V12 (09.12.2007 um 18:00 Uhr).
Dutchman V12 ist offline   Antwort Mit Zitat antworten
Alt 09.12.2007, 17:52   #2
E32Neuling
Benutzerbild von E32Neuling
Fahrzeug: BMW E39 3,0D,Ford Granada BJ82 3,0i24V V6 , 82er Chevy Camaro Targa 5,0V8
Hy ,
When i make a "Kick-Down" changes the Gearbox in the next Gear at 6000 RPM .
I think it´s normal !
E32Neuling ist offline   Antwort Mit Zitat antworten
Alt 09.12.2007, 17:59   #3
Dutchman V12
No, my gearbox does not shift up at all when i hit the kick down.
Alt 09.12.2007, 19:12   #4
Nimm12
www.hericks.net
Benutzerbild von Nimm12
Fahrzeug: M240ix Cabrio F23 / Alle E32 im Dornrösschenschlaf
Hello Dutchman,
just to ensure we are on the same page, did you push the engine to 6000 RPM ? Because you're writing "when it reaches 5000/6000 RPM or so". The part "or so" sounds to me that you're afraid to really check it out. The V12 RPM limit is 6000 RPM, means no risk to blow up the engine. Until the engine doesn't run into it's own limit: "Step on it !".
When you realize that the engine reached the limit and the gearbox isn't shifting up, than you have an issue.
But don't try this for several minutes ok ?
Cheers Guido
Geändert von Nimm12 (09.12.2007 um 19:45 Uhr).
Nimm12 ist offline   Antwort Mit Zitat antworten
Alt 10.12.2007, 02:32   #5
Try a reset, info on my website below.
I assume that you see in the dash cluster the gear and mode, for example D and M?
If not, clean the gear selector switch.
Go to my website below and click the link to Gale, he has described it.
Alt 10.12.2007, 05:44   #6
Hydromat
rogatyn
der Kickdown fährt die Gänge bis Enddrehzahl aus, solange dieser (KD) betätigt ist...
AutomatikgetriebeService Rogatyn, Kreithof 2, 85283 Wolnzach-Rohrbach, Tel. 08442 / 956208
Hydromat ist offline   Antwort Mit Zitat antworten
Alt 10.12.2007, 07:32   #7
and here the literal translation of "the master's voice"
The kickdown function is designed in such a way that the gear changes only when the RPM limiter has been reached in every gear. That continues as long as you have pushed the accell down to kick down.
That is a feature of the kickdown function, not a mal-function.
Alt 10.12.2007, 10:50   #8
Dutchman V12
Thank you all for the reactions,
I understand how the KickDown works but i don't think mine works right.
Today (after work) i will test the Kickdown again and hold it down until (hopefully) it shifts UP. I don't think this will work becouse i tried it before but maybe i didn't wait long enough.....
Tonight i will post my findings here...
Kick Down problem Blaster BMW 7er, Modell E38 14 04.05.2006 19:04
BMW E32 750i V12 300 PS didi eBay, mobile und Co 5 07.11.2004 19:50
Alle Zeitangaben in WEZ +1. Es ist jetzt 13:34 Uhr.
