Alt 07.12.2007, 21:18   #1
peter becker
750i powered by ROTTALER2
Benutzerbild von peter becker
Zitat von VollNormal Beitrag anzeigen
Gibt's auch eine Detailaufnahme von der hinteren (im Bild unteren) Kante? Da wurde die Leiste ja wohl geschnitten.
hallo andreas
nein, ich habe leider nur dieses eine bild.
viele grüsse
peter
Alt 07.12.2007, 22:36   #2
Saba
Benutzerbild von Saba
Fahrzeug: BMW e32 735i 18.12.1986 Handgeschaltet
Geile Idee ich hab auch noch 2 Tür Leisten rumfliegen, das bau ich mir auch!!!
________________________________________
Gruß aus dem Schwarzwald
Olli
Saba ist offline   Antwort Mit Zitat antworten
Alt 08.12.2007, 04:29   #3
Die Holzleiste ist die am Handschuhfach, nicht von der Tuer. Die soll laut dem "Erfinder" Erwin (fast) genau passen.
Beschreibung von ihm:
Make your own
Remove all the phone mounting hardware.
Line the inside of the cavity with felt.
You can extend the felt all the way back to the rear of the console, which makes for a sort of "hidden" compartment.
Find another piece of wood dash trim, the one that is above the glove box, in a junkyard or on eBay.
Cut the right end of the trim to fit the opening in the console. The width is perfect for this purpose. The right end of the trim will go to the front of the opening, and the cut end at the rear. Make the cut at an angle for a perfect fit.
Make a thingy to hold up the front of the trim. Screw it to the front wall of the opening, using the screw that's already there. I used some hard rubber I had laying around, cut to a point at the top left. The rear of the trim will be held up by a snug fit to the console.
Figure out a way to hinge it. I used the same felt as the lining. I cut the material wide enough to (starting next to the driver's seat):
go down the side of the opening, across the bottom, up the other side, and back across the top. I glued the felt to the walls and the trim, except for about 2 inches from the top of the right wall (to give it room to move when I open the cover).
This "hinge" is not entirely satisfactory. It won't let the lid open all the way. If anyone has better ideas, please share.
I also made a little handle thingy out of metal to help open the lid. I glued it in between the trim and the felt at the left rear. Since I used an old wiring harness holder, the exposed end was already coated, but you can probably do something similar with epoxy.
I also glued some plastic gizmos I had laying around to the inside of the trim lid, that were perfect for holding my sunglasses. Now they're easily accessible and protected.
This storage compartment is very handy, and much more useful than a dead phone.
Nach weiteren Bildern ist schon gefragt worden
original sehen sie ja so aus, aber die sind ja kaum zu bekommen gebraucht, und neu eh nicht mehr
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.bimmerboard.com/members/shogun/Holzbox4.jpg
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.bimmerboard.com/members/shogun/Holzbox5.jpg
Bild aus E34, aber passt in E32
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.bimmerboard.com/members/shogun/Holzbox6.jpg
und dann gab es ja noch die seltene kuehlbare Box fuer vorne
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.bimmerboard.com/members/s...t_cool_box.jpg
Pimp Daddy hatte mal vor Jahren diese Bilder reingestellt, da koennt Ihr sehen, wie man so einen Deckel machen koennte anhand der Vorlage Original
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://people.freenet.de/preussauto/klappeauf.jpg
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://people.freenet.de/preussauto/klappezu.jpg
Alt 08.12.2007, 18:09   #4
Standard weitere Bilder und Kommentare
As I mentioned, I need a better hinge solution. I considered the hinge for the door armrest cover, but I don't think that will work. Ideally it would be an articulating hinge, that makes the cover come out of the hole as it swings open. Plus, if it could stay in the open position, that would be awesome. I'm sure some car somewhere has something like that (or even some cabinet hardware maker).
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.bimmerboard.com/members/e...r_console1.jpg
E32-Teile: Wurzelholzleiste fuscher Suche... 5 14.08.2007 00:32
suche bild einer wurzelholzleiste mit intarsien peter becker BMW 7er, Modell E32 20 02.03.2007 19:35
E38-Teile: Suche unbeschädigte Wurzelholzleiste Beifahrertür conan Suche... 2 14.11.2006 20:50
Dringend Wurzelholzleiste mit hellem Intarsienstreifen! Alex1963 Suche... 1 11.03.2004 17:44
Fast verzweifelt wegen der Wurzelholzleiste! Alex1963 BMW 7er, Modell E32 2 02.12.2003 18:28
Alle Zeitangaben in WEZ +1. Es ist jetzt 16:17 Uhr.
