Alt 09.09.2007, 10:30   #16
Alfred G
Benutzerbild von Alfred G
Dein Vorhaben erinnert mich an die Geschichte der Dieselentwicklung bei General Motors.
Die sind so vorgegangen:
Benzinmotor nehmen, Zündkerzen durch Einspritzdüsen ersetzen und schauen was als erstes kaputt geht. Dann dieses Teil ersetzen. Dann wieder starten und dann Defekt des nächsten Teils abwarten und so weiter.
Ich glaube die haben ein paar tausend Motoren verbraucht bei diesem Vorhaben. Du kannst ja schon mal anfangen, die E32-750i-Restbestände aufzukaufen...
Übrigens:
Zuverlässig funktioniert haben die Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Ami-Diesels nie. (s.u.) Vielleicht hast du ja mehr Glück.
Oldsmobile developed three diesel engines for the 1980s - two V8s and this 263 in³ (4.3 L) V6. It was based on the Olds 350 V8 with a 4.057 in bore and 3.385 in stroke.
The history of Diesel engines at General Motors has not been positive. In the 1970s, the company was unable to power its large cars and trucks with their emissions-strangled engines. Like many other companies, GM turned to Diesel power, directing the Oldsmobile division to develop one V6 and two V8 to be shared with all divisions.
Oldsmobile's engines, the 5.7 L LF9 and 4.3 L LF7 V8s and this 4.3 L V6, were notoriously unreliable. Although over one million were sold between 1978 and 1985, the failure rate of GM's engines ruined the reputation of Diesel engines in general in the United States market. Eventually, a class action lawsuit resulted in an arbitration system under the supervision of the Federal Trade Commission where consumers could claim 80% of the original cost of the engine in the event of a failure.
The primary problem with GM's Diesel engines of the 1970s was their design — although the engines used a specific block, the design was based on Oldsmobile's 350 V8. The design had a weakness in the head design and head bolts, which were not able to withstand the higher cylinder pressures and temperatures of Diesel use.
750d - Manche Leute sind Ihrer Zeit vorraus! avr2003 BMW 7er, Modell E65/E66 11 28.12.2006 20:53
E38 V12 aus 1995: Unterbodenverkleidungen cesa1882 Suche... 0 21.06.2005 08:39
Gibt es optische Unterschiede zwischen V12 und dem Rest? indy BMW 7er, Modell E38 34 30.11.2003 20:21
Alle Zeitangaben in WEZ +1. Es ist jetzt 06:43 Uhr.
