Alt 13.06.2005, 17:59   #2
Standard so, gerade Bilder von Ron aus USA bekommen
Text:
Here are the pictures of the upper oil pan gasket repair.
I won't go into the step by step. Hopefully the pictures will be all you need. The key is the engine has to be supported from above.
Good luck.
Paparon
Shogun,
Here are my photos of how I did the upper oil pan.
I drilled 3 1/2 inch (13mm) wholes and then used a die grinder
to connect the 3 holes so I could see where the bolts were.
The last picture is of what I had to remove to get the upper pan out
Basically the subframe and all the suspension. Sway bar and the rear support units.
The exhaust does not have to be removed. It is off because I am doing the
rear diff at the same time so it had to be removed to get the drive shaft off of the diff.
I sent these to you in case someone needs to see them before I get around to posting.
I'll reduce them as well.
Ron
Synchronisieren V12 M70 Motronic Steuergeraete Erich E32: Tipps & Tricks 2 03.02.2011 11:14
Motorraum: Revision M70 V12 und Getriebe Erich E32: Tipps & Tricks 3 27.02.2008 07:39
M70 V12 Technische Beschreibung von 1987 Erich BMW 7er, Modell E32 0 13.05.2004 14:09
Wie Xenonbrenner wechseln beim V12? KJ750IL BMW 7er, Modell E38 2 17.04.2004 13:07
Wechsel der Dichtung für Kettenspanner beim M70 V12-Jodler BMW 7er, Modell E32 1 24.03.2004 09:59
Alle Zeitangaben in WEZ +1. Es ist jetzt 19:05 Uhr.
