Alt 11.07.2025, 20:45   #1
Annddrriy, you tested all this already 2 years ago, see your very long thread in BF.
Here is mentioned for the late E-7 version ZF TD/TR signal pin 21 engine speed signal TD at 800 RPM pin 21 to pin 5 35-45 Hertz, at 2000 RPM pin 21 to pin 5 100 - 110 Hertz
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://www.europeantransmission.com...MWtechinfo.htm but not voltage mentioned for pin 21
you made already tests with oscilloscope 2 years ago and even showed the diagram measuring the Hertz, see your post 626, 628, 667, 668, 737 in post 673 you posted this:
The ETM early and late version of E7 mentioned that the TCM pin 21 the engine speed signal should be around 2 volts at idle RPM 800 and between frequencies 35-45 hertz if those three components are connected together in vehicle with EML 1992. In vehicle 1990 without EML the automatic transmission TCM pin 21 pick up 13.5 volts signal from the engine fuel pump relay when fuel pump is working and sometimes frequency goes down to ground it is not stable. May I disconnect the wire number 7 connector X1537 from the engine fuel pump relay and connect to the engine ECU pin 6 or cluster X16 yellow plug pin 18 and recheck if the frequency will be stable ?
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://www.bimmerforums.com/forum/s...earning/page26
Geändert von Erich (12.07.2025 um 02:15 Uhr).
Alt 12.07.2025, 07:59   #2
Andrew1Q
Fahrzeug: BMW E32-735i (02/1990)
Yes I did test in E9 version without EML if someone could write me what is measurement in E7 or E9 version with EML ?
Should connection be made same as in EML ? Pin 21 of the TCM is the engine speed signal and fuel pump isn’t the engine speed but it’s fuel pump speed.
EML version TCM pin 21 engine speed signal takes signal from the engine ECU pin 6. Could someone measure what is voltage at the pin 6 of the engine ECU when the engine idling at RPM750 ?
Vehicle with EML the pin 21 of the TCM takes signal from the engine ECU pin 6 and vehicle without EML the TCM takes signal from fuel pump. I would like to know what is difference in voltage. E32FAN in Quebec can test it his car with EML.
Geändert von Andrew1Q (13.07.2025 um 07:56 Uhr). Grund: EML
Andrew1Q ist offline   Antwort Mit Zitat antworten
E32-Teile: Getriebesteuergerät Beat Suche... 4 31.05.2015 22:17
Getriebesteuergerät hartlb BMW 7er, Modell E38 11 05.04.2015 16:59
E32-Teile: Getriebesteuergerät bmwfreak88 Suche... 2 10.06.2009 18:55
Elektrik: Getriebesteuergerät 17er Schlüssel BMW 7er, Modell E32 3 14.06.2006 13:41
Elektrik: Getriebesteuergerät Wolf730 BMW 7er, Modell E32 4 16.09.2005 19:24
Alle Zeitangaben in WEZ +1. Es ist jetzt 17:34 Uhr.
