Alt 05.03.2017, 08:26   #3
Ja, ist auch im 5HP30 verbaut. Gibt es wohl nur bei ZF oder Getriebespezis, evtl. ist das Material ja auch inzwischen verbessert. Ich weis jetzt nicht genau, was das fuer ein Material ist, in einem US Forum gibt es folgenden Thread: Zf 5hp18 help
525i 1993, start notice after driving for 30 min the shifter became hard when I went to park or drive, I decide to change the trans oil in a service shop. Same day I took it from the garage I tried to park at home and again the shifter didnt let me to shift to P. Then I push it and suddenly the shifter went back and forward easily but none gear works. The mechanic went home and told me that the shifter cable was the problem, change it but still the same, no gears working. Again back to the service shop, they found that the manual valve of the body valve was broken (ZF part 1056-327-173), change it for a second hand part and still with the problem. Now the mechanic said that must find a new manual valve to replace it. Notice when the trans is cold I can use the shifter without problems and the car and gears drives well. until it became hot. I already bought the ZF manual valve but before install it I need an advice because I feel that something is wrong with the temperature of the transmission.
The manual valve on the 5HP series is known stick and then break. It only costs about £12 so I am not sure why anyone would fit a used one. Fit the new one and make sure the end is hooked up correctly. If you don't, you will get a box full of nothing
Thanks, the mechanic just found this piece and installed without notice
When I got my 1994 530it earlier this year, the shifter was definitely difficult to move. It finally just snapped the head off. I tried to fix it, with an obvious failure. The dirty ATF had made it brittle. $16 later, I had a brand new one in the mail. Haven't had an issue since. If the car sits for a long time or has the same fluid in certain climates, the end of the plunger swells. I actually sanded the original one down and polished it but it still managed to break. The new one works flawlessly
1056 327 173 01
5HP18-5HP18A-5HP19-5HP19FL-5HP19FLA-5HP19HLA-5HP24-5HP24A-5HP30
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Selector Valve
Im Valve body repair kit 5HP30 oder 18, die in USA verkauft werden, ist so ein Teil immer mit drin.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://i2.photobucket.com/albums/y8/...ed-1copy-1.jpg
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://i2.photobucket.com/albums/y8/...ed-1copy-2.jpg
Geändert von Erich (05.03.2017 um 09:11 Uhr).
Frontstoßstange gebrochen rpiano BMW 7er, Modell E38 13 04.11.2011 15:21
Spurstangenkonus gebrochen.... stoni BMW 7er, Modell E32 25 26.07.2011 21:51
Fahrwerk: Feder gebrochen Werner750 BMW 7er, Modell E38 2 29.04.2011 22:01
Kipphebel gebrochen Big-Bull BMW 7er, Modell E32 31 17.04.2011 11:43
Motorraum: Hydrostössel gebrochen ? DieterThai BMW 7er, Modell E32 12 17.09.2005 15:46
Alle Zeitangaben in WEZ +1. Es ist jetzt 16:45 Uhr.
