Alt 28.11.2003, 10:56   #8
Standard hier noch einmal eine typische Beschreibung aus roadfly
If the pedal goes all the way to the floor (slowly) when you hold constant pressure on the pedal, it is most likely a master cylinder going bad. A accumlator (bomb to us in the colonies) will give a rock hard pedal feel on an emergency or panic brake, and you would need to release pressure and reapply the brake to get a proper feel. The bomb is about $60-90 US at our parts outlets and takes perhaps an hour to install.
Alle Zeitangaben in WEZ +1. Es ist jetzt 19:54 Uhr.
