Alt 17.07.2009, 21:59   #1
Rosemary
Benutzerbild von Rosemary
Fahrzeug: UK right-hand drive E32-750i V12 (01.91)
Also, I'm after those plastic knobs for the boot, which connect the back plastic to the car. Any ideas?
Rosemary ist offline   Antwort Mit Zitat antworten
Alt 17.07.2009, 22:34   #2
the brake bomb is available in 2 versions
1 connection or 2 connection.
Based on your production year and RHD it should be this with 2 connections
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) RealOEM.com BMW E32 750iL Hydraulic brake servo unit
PRESSURE ACCUMULATOR 1 from built year12/1990 34331162056 $491.09
(that is realoem $ price, calculate with about 230 EURO)
so the one Volker linked above probably does not fit
Ask if it has one or 2 connections,
The one with 2 connections is probably dealer item only 34331162056
In Germany I would then buy if rom Cuntz in Speyer, you get 7-forum discount.
Go on the left to Mitgliederbereich, scroll down to Mitgliederangebote and there is Cuntz. List price is 232 EURO plus MWST and you get 20% discount in this case. Or call Patrick directly, he understands English, no problem.
Patrick's phone number is here
Interner Link) http://www.7-forum.com/forum/20/vord...ntz-99234.html
The clips for the boot are called lock 51711916197
number 10 Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) RealOEM.com BMW E32 750iL Trunk trim panel
screw trim panel, here you can see the pic better
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Pelican Parts - Automotive Parts and Accessories - Porsche & BMW
and in case you buy the trim clips in USA, the brake bomb is also much cheaper there,
and Lemforder brand! $ 189.25 is 135 EURO only, so even paying for USPS and import duty, might be cheaper, but takes longer
Alt 17.07.2009, 22:49   #3
another option to get these things cheaper is to visit Andre, he probably has them used
according to your profile you live somewhere near Wiesbaden, his shop is
ANDRE' HÖTZEL
Wiesbadener Str. 89 - 91
55252 Mainz - Kastel
Tel. : 06134 / 291912
Andre also speaks English, no problem. Just visit him and he can find out the parts you need.
Alt 18.07.2009, 09:45   #4
McTube
Benutzerbild von McTube
Fahrzeug: S50B32
Get them at the dealership, they are dirt cheap. It´s part 10, get some of 11, too, they are frequently broke and even cheaper
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Trunk trim panel BMW 7' E32, 750iL (M70) ? BMW parts catalog
Regards,
Michael
Alt 19.07.2009, 07:11   #5
Rosemary
Hey many thanks for all your help guys, gotta to check with my garage which 'bomb' belongs to my car, and gonna get some plastic knobs to make it look nice again.
Alle Zeitangaben in WEZ +1. Es ist jetzt 16:52 Uhr.
