05.05.2007, 08:56
HELP!, cant turn off alarm after replacing battery
Hello fellow german 7series owners!
I hope you can reply in english cos my german is not so good
My problem is that after I took out the battery for a resharge and then put it back in the alarm went off. I cant turn it off.
I have tried with locking the doors with key and with the remote. I have two buttons on my remote.
I localized the horn for the alarm and pulled out the cable before my neighbours could kill me
I have checked all the fuses and they are ok.
I have no idea of what to do, I cant start the car
Its a 1994 730i
Mike from Sweden
05.05.2007, 09:33
Mitglied BMW7er-Club
Hello, welcome here
Following instructions:
- Open the door, take place on Your seat and close the door.
- Turn ignition key to position "1" and let it there for 15 minutes.
- While those 15 minutes do not open any door, do not touch the key, just wait.
After having done that, alarm should be turned off.
Greetz
Norbert
05.05.2007, 09:35
Thanks for fast reply Norbert
I think I did that but maybe I did something wrong
Im gonna try that again
05.05.2007, 09:38
Just wait 20 mins - maybe, its not that exact!
Greets again
05.05.2007, 10:31
Any results?
05.05.2007, 10:52
Thanks!
15 min with key in position1 turned of the alarm
The alarm does no longer go off when opening doors etc
The LED on the dashboard, o top of center does no longer light
BUT now I cant start the car
The board computer says PPPP
The remote key doesnt work either
05.05.2007, 11:49
750i powered by ROTTALER2
hello
please look at page 62 in the following link, you find here a choice of
posibilitis, for the pppp error .
best regards
peter
http://www.e34.de/tips_tricks/bc/bc4.pdf
05.05.2007, 11:51
Thank you!
Im gonna do that
I really miss my car :(
I need it for work
05.05.2007, 14:16
Well it looks like the drive away protection is activated or I have no clue what it is
I cant make the engine run
Alarm is off, remote key doesnt work
Anyone know how to make the car run?
05.05.2007, 14:50
Remote key must be re-initialized - read instructions manual. I can't instruct You here, because Your car is newer than mine and the remote initialisation has changed from 1991 to 1994.
The "pppp" should - as it does here - go within some minutes, if u set ignition to "on" and let it there for a while. Then it should be possible to enter time/date. Try sometimes to push "time/date"-button - if You see "----" its ok again.
After that it should also be possible to start the engine.
If not so, check car battery pack - maybe its low voltage!
Greets Norbert
Geändert von Crazy (05.05.2007 um 14:56 Uhr).
