Alt 14.12.2015, 10:16   #33
Laafer
www.radio-piraten.com
Benutzerbild von Laafer
Fahrzeug: Personenkraftwagen
Zitat von Erich Beitrag anzeigen
Gibt keine neue software fuer das 4HP22/24. Ist praktisch ein reset auf die originalen Einstellungen, je nach Getriebe lernen die ja auch an nach Fahrweise (etwas, adaptive wenigstens, AGS)
Interner Link) http://www.7-forum.com/forum/24/steu...der-20320.html
Transmission adaption: Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.e38.org/electran1.pdf
Adaptive Hydraulic Pressure Control
Pressure adaptation has been a feature of ZF automatic transmissions since the 4HP22EH.
The TCM will maximize shift quality by adapting to transmission wear over time. The TCM will adjust transmission shift pressures to compensate for wear in the multi-plate clutches.This is accomplished by monitoring the input and output speeds of the transmission. When the transmission shifts, the TCM monitors the time that it takes to accomplish the shift. The time change in gear ratio is monitored and compared to an internal time value in the TCM. If the ratio change takes more time than the stored value, the TCM will compensate by adjusting the transmission shift pressures via the EDS valve solenoids. The adaptation value is stored in the TCM. This adaptation values can only be cleared by the diagnostic tester (DIS plus or GT-1).
Note: DO NOT clear adaptation values unless directed to do so by technical assistance. Clearing pressure adaptations should not be done to resolve a customer complaint. The only time that you would need to do so is after a transmission or valve body replacement or software change.
Also it is important not to confuse pressure adaptation with AGS features. AGS features will be discussed later in this chapter. AGS features are not stored on a long term basis and will not be cleared when the pressure adaptations are cleared. Note: Driving style is NOT stored.
Das Getriebe in dem Modell besitzt gar kein Steuergerät. Da es ein rein mechanisches Getriebe ist ohne EH Steuerung.
Das Getriebe hat auch keinen Programwahlschalter... und ist mittels eigenem Seilzug an die DK angeschlossen für die Gaspedalstellung
Stichworte
automatikgetriebe, getriebe, wandler
E23-Teile: Automatikgetriebe Joker023 Suche... 2 23.12.2012 16:23
Automatikgetriebe tanja735il BMW 7er, Modell E32 0 13.01.2010 07:32
Gemisch zu fett, Schnelldiagnose bitte ;-) skab BMW 7er, Modell E32 4 04.04.2009 11:12
Elektrik: Starthilfe über zweite Batterie möglich/nicht möglich? Artos BMW 7er, Modell E32 44 28.08.2008 19:13
Selbst-Schnelldiagnose: Der Stomp Test Erich E32: Tipps & Tricks 3 08.09.2003 12:08
Alle Zeitangaben in WEZ +1. Es ist jetzt 22:23 Uhr.
