Alt 16.03.2013, 10:14   #1
better forget about this old system, they changed quickly to the system with the electric motor behind the headlights, I assume it made too much trouble.
Alt 16.03.2013, 12:41   #2
Beumers
Fahrzeug: E32-735i dec 1986
Hi Erich. Hi Holger.
I'm sure you're right Erich. Yesterday I had a look while I was replacing the radiator. The 2 app's are still attached to the stabilisors. I traced the outgoing line and fond it under the hood near the exhaust. It was cut of and sealed with a screw to prevent it from leaking. So the part that devides the line to the 2 hydraulic motors and of cource the hydraulic motors themselves are missing. On the internet I can't find mutch. It doesn't show up on part searches. It's not commingly known that's for sure.
Pitty though because I like these daft things even if they don't opperate as well as planned. I'll try for a while to see if I can find the parts. If not I'll get the system out and put it on my shelf with no good things.
I also looked at the belt of the pump for the steering fluid. To loose but it's at the end of adjustment. I mennaged to get it a little bit tighter but that means nothing. It needs a new belt.
Thanks Henk.
Beumers ist offline   Antwort Mit Zitat antworten
Alt 18.03.2013, 10:44   #3
Setech
Benutzerbild von Setech
Fahrzeug: BMWs im Wechsel
Um die OT sache hier abzuschließen.
Es gab einen Nachrüstsatz für die hydraulischen Systeme.
Diese sind leider nicht mehr lieferbar:
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Nachrustsatz LWR, 63129060605 ? BMW Teilekatalog
Alle Teile gibt es zwar einzeln, jedoch fehlt der Kabelbaum.
Motorraum: VANOS noise fixed.......but another problem. Glacier BMW 7er, Modell E38 11 20.03.2011 18:18
General question + noise -> in the trunk Maarten730 BMW 7er, Modell E32 7 05.04.2009 17:41
Lenkung: steering box problems /replacement 735 750 bmw BMW 7er, Modell E32 3 18.12.2007 23:31
Lenkung: Sport steering wheel Petri BMW 7er, Modell E23 9 01.12.2005 05:22
Elektrik: display behind steering weel jelas BMW 7er, Modell E38 2 11.07.2005 20:21
Alle Zeitangaben in WEZ +1. Es ist jetzt 14:31 Uhr.
