Alt 16.03.2015, 21:46   #1
Slex
Fahrzeug: E32 740iL 93
Standard 740 and automatic transmission
Hallo.
I am from Russia and I am sorry for my english
Some of you may know that E34 540 after September 93rd year was installed adaptive transmission.
The difference in electrical minimal. This can be done independently. The question is, did anyone in this E32?
Installation in E34:
We need the button S/A
Gear Control Modul
24601421651 or 24601422022
And solder some wires
ETM e34 without adaptive transmission
ETM e34 with adaptive transmission
Comparing the differences we see that in the plug block lacks one mass, one plus and one jumper between terminals 82 and 83.
The remaining differences are control buttons.
We need to change the contacts in the connector according to the scheme, and in the end everything should work.
What's interesting is when the speeds 4 and 3, is possible to have both A and S.
With the inclusion of the same 2 S mode is automatically activated
Who can say about this?
It has long wanted an adaptive transmission. Exactly there will work in this method E32?
Slex ist offline   Antwort Mit Zitat antworten
Alt 19.03.2015, 12:09   #2
Slex
Did whom are not interested in this topic?
Or you so bad attitude towards the English language? I'm sorry, in German it would be even worse and do not understand exactly
Alt 19.03.2015, 19:21   #3
JR740
Fahrzeug: 740 i Bj09/93 ; M635CSI
Hi Slex,
It seems that you are pretty familiar with electronics.
Whatsoever, its hard for me to understand the intension of your modification
and the practicability with an automatic transmission E32 type.
Did you just swap the TCUs and change the wiring according to the second
drawing ?
The question which comes up,
- is the standard E32 transmission (5HH30), capable to understand and
communicate with the "new" transmission control unit ?
The AGS is a very sophisticated pice of electronic and I doubt if this really
works as you has described.
It would be interesting for me, if you can explain differences in driving after you have done this modification.
Sincerely
JR740
JR740 ist offline   Antwort Mit Zitat antworten
Alt 20.03.2015, 18:24   #4
Slex
I while he did not. Found a description of the modifications on the Russian forum on different cars. In particular, there are many fans of BMW. The article itself is Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) ????????? ? AGS 9.22 But it is in Russian and I am still quite accurately translated. And the picture's pretty clear.
A man who has made a modification of this car end of 95th year. Judging from the directory, all the gear to the 540 and 740 the same throughout the period of production. Were replacement part numbers, but they are interchangeable. In the end, my friend would put his third gearbox on his E34 540 and everything that interests him - it 5HP30 with black label
Hier is a link on a catalog
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://bmwcats.com/bmw/E32/47350/al...hl=24001422506
I'm not a great expert in electronics, but the plus and minus can
Alt 20.03.2015, 22:24   #5
Schorsch
BastardOperatorFromHell
Benutzerbild von Schorsch
Interesting modfication. You're really sure that this mod is not only a simulated electrical signal, but also a fully functional ATC?
Schorsch ist offline   Antwort Mit Zitat antworten
Alt 21.03.2015, 01:14   #6
Slex
Good question. Considering the fact you are using another control unit and wiring changes are likely to still this modification should lead to a positive result. However, at the moment I did not compare ETM 540 and 740, and I can not say whether or not the transmission wiring is the same. I'll try to check it out this weekend.
In addition, as one of the validation of this modification is the fact that changes the logic of the transmission with gear selector in different modes. This can be seen on the last picture.
Alt 21.03.2015, 07:31   #7
Stiefelknecht
Ärmstes Mitglied
Fahrzeug: AT 220d XDrive
Kann mir dass mal jemand anständig übersetzten
Seh ich das richtig dass die Modifikation eine "aktuelle" Ganganzeige im Cockpit bewirkt, oder hab ich das jetzt falsch verstanden?
Chris
leider keinen 740er mehr
Alt 21.03.2015, 07:55   #8
Schorsch
Noi. Woisch, Karle...
Hier gehts ums Nachrüsten der AGS aus dem E34 in den E32.
Alt 21.03.2015, 08:09   #9
Stiefelknecht
Ärmstes Mitglied
Und was bringt das bitte
Please etwas ausführlicher
(Die AGM verichtet brav ihren Dienst)
Chris
Alt 21.03.2015, 08:12   #10
Schorsch
Du kennst die AGS nicht? Oha... Adaptive Getriebe Steuerung. Der Apparat merkt sich deinen Fahrstil und dreht z.B. entsprechend höher aus. Er adaptiert sich eben an deinen Gasfuß. Hast du beispielsweise die letzten paar Kilometer kräftig beschleunigt, lässt der z.B. den dritten Gang noch einige Sekunden auf 3000 U/Min drin und schaltet erst dann hoch. Er hofft quasi, er darf noch mal rennen
Sehr, sehr geile Sache.
Automatic Getriebe wkuzio BMW 7er, Modell E32 2 17.04.2009 10:14
Bremsen: Automatic Hold Flieger BMW 7er, Modell E65/E66 4 08.03.2006 22:34
Elektrik: Automatic e36 Holger-ZX12 BMW 7er, Modell E32 0 15.05.2005 19:06
Automatic Getriebe wkuzio BMW 7er, Modell E32 2 08.02.2004 14:52
Alle Zeitangaben in WEZ +1. Es ist jetzt 21:40 Uhr.
