Alt 18.12.2007, 20:46   #1
750 bmw
Standard steering box problems /replacement 735
I have a 735i e32 with about 310.000 km on "der tacho" . The problem is a very sloppy steering and steering wheel that won't return to the straight ahead position on it's own. I adjust the screw a couple times, it seemed to help 10.000 km , but now it can't be further adjust.
I have a steering box from a 525i 12v, e34, in good shape. Is this steering box simliar to the steering box of the 735i? Does it fit in my 735i?
You can also reply in deutsch, i can understand it a little bit
750 bmw ist offline   Antwort Mit Zitat antworten
Alt 18.12.2007, 20:52   #2
peter becker
750i powered by ROTTALER2
Benutzerbild von peter becker
hello
i don´t know, if you can bolt a e34 steering box in a e32 ( i beleve yes, but not
sure) it´s possibile that the reason for your no return steering wheel is
a bad front suspension ( chamber, caster, toe in and so on)
bye
peter
have you checkt this....
Interner Link) http://www.7-forum.com/modelle/e32/lenksaeulenspiel/
this link is also very,very good
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://bmwe32.masscom.net/ ( go here to suspension and steering)
Geändert von peter becker (18.12.2007 um 21:01 Uhr).
Alt 18.12.2007, 21:19   #3
750 bmw
i replaced al 4 of my suspension arms (biltstein with powerflex), also I replaced the shock absorbers for sachs supertouring. The springs are from eibach. I readadjust the toe in (2mm). The chamber and caster isn't adjustable with the e32 /e34.
Alt 19.12.2007, 00:31   #4
VMartin
fahrendes Mitglied
Benutzerbild von VMartin
Fahrzeug: 735i E65 (11/2001) & 740 F01 (12/2009)
Hello!
I think it wouldn't work. There must be a major difference, (about 1.7 kg) if you beleve to Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) THIS
Austausch hydrolenkgetriebe
Part number: 32 13 1 139 745
Old part number: 32 13 1 137 498
Supplement:
Weight (kg): 13,550
New part number: 32 13 1 139 741
Part use
7' E32
Part number: 32 13 1 135 630
Old part number: 32 13 1 134 265
Supplement:
Weight (kg): 11,860
New part number: 32 13 1 135 672
Part use
5' E34
Greetings
Martin
735i Titan-Grau Met. BJ 02 (V8) 165.000 km
VMartin ist offline   Antwort Mit Zitat antworten
Abgasanlage: What problems to look for on 730d? Mr-Heier BMW 7er, Modell E65/E66 4 30.03.2007 22:43
Fuel tank replacement - Where to buy? MVI BMW 7er, Modell E38 2 09.08.2006 22:08
Lenkung: Sport steering wheel Petri BMW 7er, Modell E23 9 01.12.2005 06:22
Elektrik: display behind steering weel jelas BMW 7er, Modell E38 2 11.07.2005 21:21
Several problems with '91 735IA Odegard BMW 7er, Modell E32 4 23.04.2003 18:27
Alle Zeitangaben in WEZ +2. Es ist jetzt 18:22 Uhr.
