Alt 05.12.2005, 09:03   #3
Sinclair
Benutzerbild von Sinclair
Fahrzeug: E38 750i 3/2001
Top! charging the two batteries in 750i
I have a slight different view, please correct me, if anyone knows better:
0. car is not started, but only measurements are done
1. if I measure voltage across the motors' jump start poles, I get 12.8 V
2. if I measure at the cigarette plug inside, I get 12.1 V
3. if I start the car, after 3 sec the system voltage ramps up to 14 V
and the smaller board battery is charged, too.
I conclude:
a) at point 1), see above, I measure the larger starter battery
b) if the car is switched off, the two batteries are not connected via the switch, they are electrically separated.
c) the smaller board battery on-top (see point 2), is charged during normal running, together with the larger starter battery, using the automatic interconnection switch, then closed.
d) if one wants only, to recharge the smaller board battery (70Ah), then it is usefull, to connect the external charger directly to the bord battery. I use an additionally build-in 12V connector to that battery (where I otherwise connect e.g. a cooling box), the additional connector is 16A-fused for safety.
But be careful, to stop "constant current charging process", when 14.2 V are reached. I recognized a buzzer, when voltage is higher than charge end voltage ?
e) I'm not sure, if by charging the large starter battery (110Ah) using the start poles at the engine compartment, that the smaller board battery will be charged two, because the separation switch seems normally opened, when the car is not running.
Sinclair ist offline   Antwort Mit Zitat antworten
Fahrwerk: Bitte um mithilfe - Habe Einige Fragen zur Achslast beim 750i Teilemann BMW 7er, Modell E32 7 12.04.2005 15:52
Viele Fragen zum e38 750i Umbau/Tuning sk8terboy BMW 7er, Modell E38 14 18.03.2005 18:39
Motorraum: 740i mit gesperrten Diff aus 750i ! & jede Menge Fragen Teilemann BMW 7er, Modell E32 10 05.10.2004 10:47
Kaufberatung und Fragen 750i E32 HenningV12 BMW 7er, Modell E32 3 10.01.2004 14:37
Bin neu hier! Hallo! Und gleich Fragen zum 750i CD BMW 7er, Modell E38 8 06.11.2003 07:07
Alle Zeitangaben in WEZ +1. Es ist jetzt 11:32 Uhr.
