Alt 27.01.2016, 11:43   #2
Andimp3
Benutzerbild von Andimp3
Auf die schnelle habe ich jetzt nur eine englisch-sprachige Gesamtliste zur Hand:
6BMOT - Engine electronics MS 80 6 Cylinder N51/N52K
ABG - Airbag Module
ABS*- Anti-Lock Brakes
ACC*- Active Cruise Control
ACC2*- Active Cruise Control 2
ACSM - Advanced Crash and Safety Management
AEWS - Immobilizer
AHL*- Adaptive Directional Headlights
AHM - Trailer module
AIC - Automatic Interval Control
AKMB - Instrument Cluster
AL - Active Steering
ALBBF*- Active Backrest Width, Front Passenger
ALBFA*- Active Backrest Width, Driver
ALSZ - Light Switch Center
AMP - Amplifier
AMPH - HiFi Amplifier
AMPT - Top HiFi Amplifier/System
ANT*- Antenna/Antenna Tuner
ARS*- Dynamic Drive
ASC*- Active Stability Control
ASK*- Audio System Controller
BABG - Airbag Electronics
BIT - Telematic Control Unit
BFS - Passenger Seat Module
BM - OnBoard Monitor
BTM - Passenger Mirror Module
BZM - Control Center, Center console
CA - Comfort Access
CAS - Car Access System
CCC - Car Communication Computer
CCC-A - Applications
CCC-ANT - Aerial Tuner
CCC-ASK - Audio System Controller
CCC-GW - Gateway
CD - Control Display
CDC - CD Changer
CEM - Clean Energy Module
CIC - Car Infotainment Computer
CID - Central Information Display
CON - (front) I-drive controller
CTM - Convertible Top Module
CVM - Vert Module (Convertible Top Module)
DAB - Digital tuner
DDE - Digital Diesel Electronics
DME - Digital Motor Electronics
DSC - Dynamic Stability Control MK60E5 DSC+
DSP - Digital Sound Processor
DVD - DVD Changer
DWA - Anti Theft alarm system
DWS - Deflation Warning System (= RDC low cost?)
ECALL - Combox Emergency Caller
EDC - Electronic damper control
EDC SHL - Electronic damper control, rear left satellite
EDC SHR - Electronic damper control, rear right satellite
EDC SVL - Electronic damper control, front left satellite
EDC SVR - Electronic damper control, front right satellite
EGS - Electronic Transmission Control Unit
EHC - Electronic ride-height control
EKP - Electric fuel pump 3 Generation
EKPS - Electronic fuel pump control
EMA LI - Automatic reel, left
EMA RE - Automatic reel, right
EMF - Electromechanical parking brake
EML - Electronic engine power control
EPS - Electronic power steering
EWS - Vehicle immobilizer
FAS - Driver's seat module
FBI - Flexible bus interface
FBZM - Rear compartment control center, center console
FCON - Rear compartment controller
FD - Rear compartment display
FD2 - Rear compartment display 2
FID - Read compartment information display
FKA - Rear compartment heating/air conditioning system
FLA - High beam assistant
FRM - Footwell module
FTM - Driver rearview mirror module
FZD - Function unit roof
FZD - Roof function centre
GM5 - ZKE - Central Body Electronics
GR- Cruise control
GT - Navigation (older models I presume)
GWS - Gear selection switch
HKA - Rear automatic air conditioning
HKL - Rear lid lift
HSR - Rear axle slip angle control
HUD - heads up display unit
ICM - Integrated Chassis Management
IHK - Climate Control/AC
IHKA - Integrated automatic heating/air conditioning system
IHKR - Integrated heating / air conditioning
IKE - Instrument cluster
IKI - Instrument cluster
INSTR - Instrument cluster
JBE - Junction box electronics
KAFAS - Camera-based driver support systems
KMB - body module
KGM - body gateway module
KHI - Headphones interface
KOM - Instrument cluster
KOMBI - Instrument cluster
LCM - Light switching center
LEW - Steering angle sensor
LM - Lights module 2
LMA - light module
LRA - Automatic headlight vertical aim control
LRR - Longe range radar
LSZ - Lights switching center
LSMC - Left Stepper Motor Control (Adaptive Headlight Module Left)
LWS - Light Switch
M-ASK-BO - User interface
M-ASK-GW - Gateway
M-ASK-NAV - Navigation system
MEDIA - Combox Media / Telephone
MFL - Multifunction steering wheel
MID - Multiinformation display
MIR- Multiinformation radio
MOST - Media Oriented System Transport
MPM - Micro power module
MRS - Multiple Restraint System
NAV - Navigation computer
NFRM - Driver's side footwell module
NVE - Night vision electronics
NVK - Night vision camera
PDC - park distance control
PGS - Passive Go System
RAD - Radio
RAD2-BO - User interface
RAD2-GW - Gateway
RDC - Tire pressure Control Low Cost BN2000
RDC - Tyre pressure control
RDW - Tyre pressure control
RFK - Reversing camera
RLS - Rain/Light Sensor
RLSS - Solar rain / light sensor
RSE - High Rear-seat entertainment Professional
RSE - Mid Rear-seat entertainment
RSMC - Right Stepper Motor Control (Adaptive Headlight Module Right)
SASL - Satellite A-Pillar left
SASR - Satellite A-Pillar right
SBSL - Satellite B-Pillar left
SBSR - Satellite B-Pillar right
SDARS - Satellite tuner
SEC1 - Supplementary control unit 1
SEC2 - Supplementary control unit 2
SES - Language input system
SFZ - Satellite vehicle center
SG-FD - Control unit, rear compartment display
SG-FD-GW - Control unti, rear compartment display, gateway
SGM-SIM - Safety and gateway module
SGM-ZGM - Safety and gateway module
SHD - Sliding / tilting sunroof
SHZH - Independent / aux. heater
SIM - Multiple restraint system
SINE - Siren with tilt sensor
SLM - Seat memory driver
SMBF - Seat module passenger
SMBFH - Seat module passenger side, rear
SM - Seat Memory
SM BA - Passenger's seat module
SM BFH - Seat module, passenger side, rear
SM FA - Driver's seat module
SM FAH - Seat module, driver's side, rear
SMF - Seat memory driver
SMG - Sequential Manual Gearbox
SSH - Satellite, seat, rear
SPMBT - Mirror memory passenger
SPMFT - Mirror memory driver
SSBF - Satellite, seat, passenger
SSFA - Satellite, seat, driver
STH - Park heating
STVL - Satellite, door, front left
STVR - Satellite, door, front right
SVS - Language processing system
SVT- Servotronic
SZL - Switch center steering column
SZM - Switching center, center console
SWW - Lane change warning
SZL - steering column control unit
TCU - telematic control unit/ bluetooth telephone
TEL - Telematic control unit
TGBT - Passive Go System
TGFT - Passive Go System
TMBF - Door module. front passenger
TMFA - Door module, driver
TPMS - Tire pressure monitoring system
TLC - Lane departure warning
TRSVC - Control unit for the rear view camera and SideView
E38-Teile: Steuergerät Xenon-Licht E38 Stefan Klenner Suche... 1 25.10.2015 16:01
Was bedeutet die Abkürzung DME und wo sitzt das Teil? witchr BMW 7er, Modell E38 4 19.01.2010 15:41
Wofür steht die Abkürzung "LCI"? schutzschi BMW 7er, allgemein 2 17.11.2006 15:12
Steuergerät für Licht KLM!? MadMax67 Suche... 5 26.01.2006 15:02
Alle Zeitangaben in WEZ +1. Es ist jetzt 21:16 Uhr.
