ENGINE APPEARS TO MISFIRE OR STUMBLE INTERMITINTLY
MODELS AFFECTED: 5 Series(E34), 7 series(E32), 8 series(E31) all equipped with ACS.
FAULT: Under certain specific conditions an apparent engine misfire or bucking may occur. This is not
an engine misfire.
CAUSE: Short (less than 100 milliseconds) fuel injection cut-off, as a result of MSR (engine drag torque
control) regulation. This is a normal ASC function that may occur under these conditions:
-The vehicle is equipped with ASC
-Vehicle speed between 45 and 60 MPH
-A rough road surface (e.g. potholes, railroad tracks)
-Light throttle(accelerator pedal only depressed 1/8)
-ASC not switched off.
SOLUTION: Replace the ASC control unit. no further diagnosis of the ABS/ASC system should be
necessary.
Advanced Hints and Tips : BMW ABS problems
