01.04.2008, 22:09
Fahrzeug: E32-730i (11.89)
Electric and transmission
Please HELP me. I can not speak German, so I decided to write in English. Sorry.
My problem:
I bought E32 730i (11/1989). There was a problem with automatic transmission. When I am trying to move in D, it will start moving with 2nd gear. After 10 - 15 meters there is 1st gear and it is still there until 6000 rpm and then tha transmission gives me the 4th gear - so I can drive a little bit faster. So there is no 3rd gear. It will come to 2nd gear, when I am driving around 20km/h. It is always the same even when I am trying to start with position 1 or 2 or 3. (except the 4th gear of course). In BMW they told me, that everything electric (control unit of transmission) is OK and there must be mechanical problem in transmission. So I bought another transmission with a control unit from a guy, who drove the transmission on a car (E32 730i 1987) from Germany to Czech republic. I changed the transmission and control unit. After starting the engine there was GETRIEBE PROGRAM. In BMW they told me, that there was one control unit until 9/88 and another one after 9/88. So I connected the original control unit and it was the same. So IT IS NOT MECHANICAL PROBLEM. Then they told me, that I need another control unit. I found the same one as I need - AND IT IS THE SAME.
PLEASE, let me know, how to check the cables from transmission to control unit if they are OK, where are all the connectors that need to be cleaned and what kind of sensors on engine are cooperating with control unit of transmission. I AM DESPRED. I THINK THAT I CAN FIND HELP HERE WITH YOU!!! I TRIED ALMOST EVERYTHING.
THANK YOU FOR YOUR ANSWERS.
01.04.2008, 22:34
Contact "Fugo" = Jakub in Jablonec nad Nisou, you can talk to him in the same language and he is an expert on the E32.
Here you can send him an email or U2U private message
http://www.7-forum.com/forum/member.html?u=8338
checking the cables: see my website below, there is a link to europeantransmissions.
Test data are there.
02.04.2008, 06:25
Fahrzeug: Ford Transit und Kawasaki ZX10R
Napiš mě česky nebo slovensky, anglicky ti nerozumím, nebo můžeš pohledat na bmwklub.cz
(Schreibst du mir tschechisch oder slowakisch, english verstehe ich nicht, oder kannst du auf bmwklub.cz finden)
MfG Fugo
02.04.2008, 17:02
Ex M60-powerd by LPG
Hello
maybe that you have an defect in the "gear selector switch". Read here:
Switch 1
Switch 2
Best wishes
Wolfgang
12.04.2008, 20:47
Everything is all right now!!
DE:
Danke FUGO fur deine elektrik scheme. Ich habe 8-pin getriebe und nur 7 kabel in das auto. Ich gibt 1 kabel mehr fur pin 2 das getriebe zu pin 20 an getriebesteuerung und alles ist OK. DANKE FUR DAINE HILFE!
EN:
Thank you FUGO for your electric scheme. I have 8-pin transmission, and there was only 7 cables connected to transmission. So I have connected one more cable from pin 2 on transmission to pin 20 on transmission control unit. THANK YOU FOR YOUR HELP!
