Alt 10.12.2007, 20:23   #11
Dutchman V12
Benutzerbild von Dutchman V12
Fahrzeug: BMW E32 750i 05-1993
Hi there!
Thank you, i did the VIN check see here the results:
Chassis number DC09840
Vehicle code GB81
Series E32
Model 750i
Body type saloon
Catalog model ECE
Production date 1993 / 05
Engine M70
Transmission Automatic
Steering Left
Catalyzer YES
Additional Information for Vehicle code GB81
Production FROM : 1990/09/01 TO : 1994/03/31
Engine M70 B50
Engine Oil 7.50 Liter
Transmission Model 4HP-22/EH
Transmission Oil 3.50 Liter
Rear Axle Oil 1.90 Liter
Coolant(w/o Air Conditioner) 0.00 Liter
Coolant(with Air Conditioner) 13.00 Liter
Brake fluid 1.00 Liter
Remarks :
I also added some information in my profile. Is there also the possibility for uploading pictures of the car to your profile?
Grtz.. Bart
Dutchman V12 ist offline   Antwort Mit Zitat antworten
Alt 11.12.2007, 02:30   #12
Thanks.
to add a picture of your car in the avatar, click on the left side Mitglierderbereich, then scroll down to Kontrollzentrum Einsrellungen & Optionen, click Benutzerbild aendern and then proceed to upload the picture from your PC.
Max. size is 180 x 150 Pixel und 15,0 KB.
To upload a pic from your PC when you post, just scroll down a bit more below the usual click for sending
Just for info: Production numbers of 750 in 1993 was 1.418
quite rare car
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://bmwe32.masscom.net/johan/info...roduction.html
Alt 11.12.2007, 19:33   #13
Dutchman V12
Thanks man! I didn't know that..
Nice to know....
Alt 11.12.2007, 21:25   #14
osl jaap
street-legal racer
Benutzerbild von osl jaap
Fahrzeug: 633 csi 1980 /Renault Megane Estate plug in Hybrid 2022/ Kawasaki zzr600
hallo Dutchman v12,
Veel plezier hier op dit forum. Ik zit hier al weer een tijdje op en elke keer wordt je goed geholpen.Mocht je iets uit het duits willen vertalen of naar het duits willen vertalen kan ik je wel helpen.
Ciao,
Osl Jaap
osl jaap ist offline   Antwort Mit Zitat antworten
Alt 11.12.2007, 21:55   #15
peter becker
750i powered by ROTTALER2
Benutzerbild von peter becker
Zitat von Dutchman V12 Beitrag anzeigen
Hi there!
Vehicle code GB81
Series E32
Model 750i
Body type saloon
Catalog model ECE
Engine M70
Steering Left
Catalyzer YES
Engine M70 B50
Remarks :
Grtz.. Bart
hey bart
i am wondering, 4 HP22 as automatik transmission??????
i think, the 750 ( e32) was build with the 4 HP24.......
grtz peter
Alt 12.12.2007, 02:40   #16
Peter, that is a mistake in the system, it is 4HP24.
But the housing of the ZF tranny shows in the metal always 4HP22, even in E30 3 series, which uses the same housing.
The PLATE on the tranny with serial number from ZF is the deciding point.
Kick Down problem Blaster BMW 7er, Modell E38 14 04.05.2006 20:04
BMW E32 750i V12 300 PS didi eBay, mobile und Co 5 07.11.2004 20:50
Alle Zeitangaben in WEZ +1. Es ist jetzt 14:16 Uhr.
