Alt 04.01.2003, 14:10   #2
Chaabo
nicht mehr dabei
Fahrzeug: keines
Hi Schnitzer,
It's simply the gauge-testing-routine of the instrument cluster.
Once started as you decribed it, you could lean back and watch...
But you are not able to do any adjustments!
If You want to change the language on the instrument cluster display You have to insert the key and turn it one step. After pressing and holding the right button on the instrument cluster for about 10 seconds the OBC will tell you what language it now has switched to. To reache the language you want just press the button again.
This is afak the only adjustment that can made to the OBC.
Greets,
David.
Chaabo ist offline   Antwort Mit Zitat antworten
Alle Zeitangaben in WEZ +1. Es ist jetzt 00:57 Uhr.
