Alt 21.05.2006, 12:23   #2
osl jaap
street-legal racer
Benutzerbild von osl jaap
Hello kriss,
The rebuild kit should be available at an Australian BMW dealership. The heat shield rings you refer to are the number 08 and 09 in the drawing and no longer available as part seperately. These rings protect the rubber seals against tear when pushing the pistons back to mount new linings.
For the linings can i provide you with two part numbers of linings i can buy in holland. the numbers refer to an 850 csi which uses the same 4/piston calipers but larger rotors. The TRW/Lucas linings are in my car with original BMW discs and work very well.
GDB 1161 TRW/Lucas-Girling
20309
0986424185 Bosch-ATE
BP 015
The mounting kit you mentioned is also only available throug the BMW dealer .
Ciao,
Osl Jaap
Es ist soweit! BMW Prospekte, EBAs, Unterlagen u.s.w. auf PDF! ferri BMW 7er, Modell E32 111 09.07.2013 19:51
Bremsenteile Gleich Bei E34 und E32 ?? Manek84 BMW 7er, Modell E32 3 13.08.2005 10:26
750i E38 vs. 750iL E32.... nach 6 Wochen Erfahrung. ferri BMW 7er, Modell E38 0 23.03.2005 08:13
Reparatur Anleitung Verlag Bucheli (so Schlecht!!!!) arc_master BMW 7er, Modell E32 17 29.11.2003 16:44
Alle Zeitangaben in WEZ +1. Es ist jetzt 08:00 Uhr.
