Alt 04.10.2007, 02:13   #1
Superb
Benutzerbild von Superb
Fahrzeug: E39,E34
Standard Problem mit memory-sitze
(E34 540ia -93)
The right back of the driver's seat doesn't go down, left goes down (motor works) and the whole seat is about to crack.. also the headrest doesn't go up or down, but the electronic motor works fine. Manual adjustment is possible for the headrest.
Electric seat with memory, any help please?
Superb ist offline   Antwort Mit Zitat antworten
Alt 04.10.2007, 02:38   #2
Looks like you have the socalled seat back twist, here some instructions how to shorten the cable
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.pagaduan.org/bmwe32/Fahrersitz.htm
English, nice info from Winfred for E34/E32
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://bellsouthpwp.net/m/i/miales/seatcablesfix.htm
Also go to my website below, on the link to Gale there are more instructions about seat back twist, seat back motor, and also how to change the gear of the seat.
Headrest: pull the headrest once more out and then push it in again, it seems that the 2 brackets of the headrest are not fully set into the gear of the system.
Alt 04.10.2007, 18:26   #3
Superb
Fahrzeug: E39,E34
Thank You!
Repaired it and everything started working as new!!
Alt 05.10.2007, 03:36   #4
Superb
Fahrzeug: E39,E34
Is it true that the electric motor and the mechanical parts to the electric lumbar support is already on this comfortseat?
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.gunnar525.de/screwings_be...e_e_einbau.pdf
I saw that blue connector hidden in the seat..
Innenraum: Memory-Sitze ohne Memory Pace BMW 7er, Modell E32 3 10.10.2004 19:26
E-Sitze mit Memory Thomy7er BMW 7er, Modell E38 15 03.11.2003 23:14
elektrische Sitze mit Memory anschließen Dieselflink BMW 7er, allgemein 0 13.06.2003 18:57
sitze, memory snorrepoes BMW 7er, Modell E32 0 02.11.2002 21:44
MEMORY SITZE ???????????? BONO BMW 7er, Modell E32 4 22.08.2002 11:02
Alle Zeitangaben in WEZ +1. Es ist jetzt 06:11 Uhr.
