Alt 14.04.2004, 23:01   #1
Standard Anzeige esd regelt? Infos dazu
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Check control Modul
Alt 03.01.2009, 13:52   #2
bessere und ausfuehrlichere Links dazu
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.e34-welt.de/tips_tricks/R...0e34%20e32.pdf
und auf meiner Seite mit Bildern
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) DIAGNOSIS - CHECK CONTROL MODULE
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Shogun's Tips and Tricks for the Seven Series
Alt 11.02.2009, 13:39   #3
sicherheitshalber hab ich mal den uralten Post aus USA kopiert:
Check Control Module - advanced course (archive) [ 7-series (E32) Message Board ]
Posted by Kevin on March 30, 2002 at 20:43:14:
(posted from: adsl-63-194-216-215.dsl.snfc21.pacbell.net (63.194.216.215))
Some may have seen a message posted earlier this week on "ESD Regelt" and my response about that message possibly indicating a fault in the check control module... well, as fate would have it, less than 24 hours after I posted that message, I got the same dreaded message! OK, time to take some of my own medicine. I pulled the check control module today and began to do some serious triage. For those who have cracked the cases on the CCM, you'll no doubt recognize a highly symetrical design. This is for a reason... there are about 30 separate, but identical test circuits in the CCM that check everything from your brake lights to the key in the ignition. Every single one of these test circuits is set up as what is known in the business as a "current loop". That means that the system sends a current through the closed loop of the and measures the voltage drop across a precision resistor. If the drop is out of range, you get an error. Not to difficult. Anyway, to debug my CCM, I took the cases off and put it back in the car and started the engine. Immediately I got the ESD Regelt error. Using my multi-meter, I started testing the voltage at the precision resistors. All were the same... accept for 1. Hmm. I pulled the CCM and put it on the bench. Again using the multi-meter, this time in ohms mode, I measured the precision resistors. Each bank of precision resistors has 4 2K ohm resistors and 1 1K ohm resistor... again, nice symmetry. Problem was, one of my 2K ohm resistors was 2.7K ohms... since I did not have any spare precision resistor networks laying around, I instead calculated that an 8.2K ohm resistor in parallel with the suspicious 2.7K ohm resistor would bring the value back down to the required 2.0K ohms. 30 seconds of soldering and the new resistor was in place. I left the case off the CCM and plugged it back into the car. Hey, no more ESD-Regelt! I checked the voltages and all were exactly the same - as they should be.
Anyway, thought I would post this since this is one of those gremlins that could be hard to track and cure... it's sort of the analog to the capacitor fix for the cluster. Of course, this problem could have been solved by purchasing a new or refurbished CCM... but then again, we're all trying to keep that cost of ownership down!
Kevin
Und George Mann, ein weiterer Expertes aus 2004:
Author: George Mann on 2004-08-28
Rick, the CCM stands for Check Control Module and is located in the fusebox. Below is a brief description of its operation from a previous board member who took the dive:
Lastly Rick, your problem is likely a wire issue though. You didn't answer my comment about whether you wired both hots to ground at the same time and if that resolved your problem. You may have difficulty finding a CCM specific diagram for the rear suspension camber switch but if you pour through the Power and Ground Distribution diagrams in the back of Bentley you will find many color coded wire inputs from various monitored systems into the Check Control Module. I would likely use a multimeter with the CCM out of the car to find the appropriate wires from the camber switch to the CCM...not that difficult. If you establish you are getting continuity from the two wires from the camber switch back to the CCM, then open the CCM and find the discrepant resistance per the above method. If you are mildly adept at electronics, you now have all the information you need to resolve your problem.
Good Luck,
George
Geändert von Erich (11.02.2009 um 14:01 Uhr).
Alle Zeitangaben in WEZ +1. Es ist jetzt 22:07 Uhr.
