Alt 06.09.2005, 12:38   #1
Salih2
Fahrzeug: 730I
Standard BMW 730i E32 windows
my friend I am very happy to website helping me.
My BMW730i year model 1990 with E32
I have problem with windows open and close
like when i driver my car windows not work after may be 15 it work (close and open) may after 25 minutes again it stop work not close not open
your advise oplz
Salih2 ist offline   Antwort Mit Zitat antworten
Alt 06.09.2005, 14:35   #2
HighWheels
Always straightforward!
Benutzerbild von HighWheels
Fahrzeug: '94 Brodie Expresso
Salam aleikum,
I suppose this is a broken cabel inside of your door panels.
I had the same appearance on my old 735. When I followed the wiring harness from the body to the inside of the door, I found one cable broken, causing the interruption.
I often read about this problem, it is one typical kind of our E32 bimmers.
Peace,
Fred
Wäre es nicht adäquat, den Usus heterogener Termini zu minimieren?
HighWheels ist offline   Antwort Mit Zitat antworten
Alt 06.09.2005, 14:44   #3
HighWheels
If this failure appears at all windows simultaneously, I would suspect one of the modules "RM" or "GM" located under the rear seats at the central car electronics. Maybe only a loose connection.
Alt 06.09.2005, 15:00   #4
Salih2
Fahrzeug: 730I
Standard Many Thanks -but happen to all windows
My friend that happen to all windows,now which cable is must chceck first.
thx
Alt 08.09.2005, 04:00   #5
my friend,
under the rear seat there are hundreds of cables. I know it because I just disassemble a car. If you cannot read wiring diagrams, then you are lost. Wiring diagrams are on my website.
But first of all do the following:
-remove the window switches in the center console and clean them. Often some drink spills into that area and the switches are not having contact.
-check on the rear windows the switches at the doors. Do they work?
If they work, then I would exclude the GM and RM under the rear seat.
But you can remove the GM and the RM and spray the contacts on them.
Broken wires in doors: usually where they go from the A-pillar into the door.
Check the drivers door first as this is most often used. Open the door and check if the windows are working in different positions of the door open.
See here
Elektrik: Suche Schaltplan BMW 730i E32 Mac Schoeni BMW 7er, Modell E32 9 21.05.2011 10:52
E32 730i V8 gesichtet WOLF BMW 7er, Modell E32 21 01.04.2005 14:16
V8-Emblem für BMW 730i (E32) V8 ??? tobu BMW 7er, Modell E32 23 08.09.2003 14:52
Alle Zeitangaben in WEZ +1. Es ist jetzt 21:00 Uhr.
