Alt 14.06.2005, 06:36   #1
Standard MAF performance upgrade fuer M30 Motor
damit der 735 noch schneller wird als er schon ist
Das scheint mir eines der vernuenftigen Tuningwerkzeuge zu sein:
The Mass Air Adaptor is engineered to OE standards and guaranteed for parts and workmanship for the life of the product. The Calibrator is designed to give the end user the ability to convert from vane to mass air measurement, with less restriction, and match the MAF calibration to a specific application. It allows for adjustment for larger injectors. This makes it applicable to engines of horsepower up to 3 times stock. Or in stock application, it allows adjustment to optimize air/fuel ratio at all engine speeds. Four adjustments on the MAF controller and computer software are provided to adjust the Mass Air Meter’s output voltage to the perfect flow for your engine. This signal is then processed, to convert the mass air signal to the volumetric vane signal your engine computer expects. This involves circuits to change the transfer function using temperature sensors to convert the mass signal to vane volumetric signal to the DME. These circuits are factory calibrated but are fully adjustable.
$609.00
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.racingking.net/Performanc...?ProductID=102
M30 B35 Motor DD Suche... 2 07.06.2004 18:58
Alle Zeitangaben in WEZ +1. Es ist jetzt 14:08 Uhr.
