Alt 31.01.2010, 08:16   #1
Maarten730
Fahrzeug: E32/730i- '87 (S38B36)
Frage How to connect the horn E38 mfl -> E32?
My mechanics have changed my (standard) steering column in my E32 from a non-airbag / to an airbag column (where the "steering pin" is a bit shorter).
Too bad that I have mounted a regular (non airbag) M-tech steeringwheel ;(
It drives with a "little bit" clearance
Now I have bought a e38 MFL (airbag) steering wheel and want to change the steeringwheel..
I don't want to connect all the functions, there my old steering column will be replaced in time from airbag to non-airbag.
How can I connect the horn without to much modifications ?
If I am not mistaking my old steering wheel had a blue and brown wire for the horn.
Are you able to tell me the easiest way to connect the horn for this e38 MFL airbag steering wheel on my current steering column (also the blue and brown wire)? ps. blue wire is standard connected into the steering wheel
Maarten730 ist offline   Antwort Mit Zitat antworten
Lenkung: E38- Lenkrad im E32 / MFL. Umbau möglich? Manu740i BMW 7er, Modell E32 3 25.09.2009 05:03
Elektrik: Horn ohne Strom rolf2000 BMW 7er, Modell E32 5 30.03.2006 13:29
Innenraum: Connect Adapter für Sony MP3 Wechsler GSX-Heizer BMW 7er, Modell E38 1 10.11.2005 17:43
Innenraum: MFL im E32 ??? Wolf730 BMW 7er, Modell E32 11 17.09.2005 07:51
Alle Zeitangaben in WEZ +1. Es ist jetzt 16:57 Uhr.
