Alt 07.07.2008, 19:16   #1
Rosemary
Benutzerbild von Rosemary
Fahrzeug: UK right-hand drive E32-750i V12 (01.91)
Standard Transmission again, question to Erich
Hello Erich,
since you are in Japan and cars there drive on the left (right way) side, just like in the UK, I have a transmission question, please.
In a previous post I mentioned that my transmission gave up going in reverse. And that I was going to buy a second hand one from a dealer or ebay here in Germany. But you gave me some excellent contacts to telephone as well.
Now I get different suggestions: One BMW garage man says that you cannot fit a German transmission in a UK right hand drive, another garage man says it makes no difference.
I will call Andre Hötzel to get my transmission fixed, replaced, whatever. in the meantime please tell me who's right. Meant to say it's an automatic as well (forgot to mention)
Many thanks
Geändert von Rosemary (07.07.2008 um 19:52 Uhr).
Rosemary ist offline   Antwort Mit Zitat antworten
Alt 07.07.2008, 19:36   #2
Nils024
Fahrzeug: nix
it is correct that the right hand drive models (UK and Japan) have a different gearbox when it comes to partnumbers. no idea what the exact difference is. could be some minor electrical/valve difference, but could also be a mechanical difference aswell. unless someone actually tried to fit a LHD gearbox to a RHD car you wont know for sure it it fits or not.
Nils024 ist offline   Antwort Mit Zitat antworten
Alt 07.07.2008, 23:58   #3
I assume there is a difference in gears. The 4HP22/24 is used in many cars, such as the E30, E34, E32, E31 series. Depending on the model the lever of the gear change is either on the left or on the right side. The shaft however goes thru the complete transmission and you could install the lever on the other side.
Maybe the small brackets you have to change, but that even has to be done by us on the same car when installing a new transmission. Can be used from the old one.
BUT, now I have checked the realoem, and selected as example a 750iL 01/1990 and this pops up
FOR VEHICLES WITH
NATIONAL VERSION COMMONWEALTH
L804A=YES
01 RMFD AUTOMATIC TRANSMISSION EH
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) RealOEM.COM * BMW E32 750iL AUTOMATIC TRANSMISSION 4HP24
that when I select left hand drive
and strange enough, this shows when I select RHD
Maybe you call JPAT in the U.K., they are the specialists
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) JPat - Automatic Transmissions - Welcome
E32 735,750 question malik22 BMW 7er, Modell E32 14 17.08.2007 09:31
English speakers-Question Need Help! silver50 BMW 7er, Modell E65/E66 6 20.07.2006 19:04
Speak English?? Question Please silver50 BMW 7er, Modell E38 10 10.02.2006 00:31
OBD question EmilC BMW 7er, Modell E38 1 21.04.2005 17:20
Elektrik: a little question nummer22 BMW 7er, Modell E38 0 17.07.2004 19:15
Alle Zeitangaben in WEZ +1. Es ist jetzt 06:08 Uhr.
