Alt 25.12.2007, 05:47   #1
Standard Oelleckage M70 V12 vorne rechts?
Also auf der Beifahrerseite?
Dann hier mal weiterlesen und die Anleitung runterladen.
Chances are, the o-ring on the chain tensioner is worn, allowing oil to leak out. This is another common problem on the V12 engines. The procedure shows you how to access the tensioner assembly for removal and repair.
Contributed by: Mark Fling (MarkinSBA)
To learn more, download the att121.pdf file below.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.e31faq.com/Default.aspx?catId=88
Alt 23.04.2009, 08:41   #2
Engine Coolant Leaks On 1988-90 BMW 5.0L Engines
AERA members have reported engine coolant leaks on 1988-90 BMW
5.0L engines. The coolant seems to be coming from the coolant
chamber cover on top of the engine block due to a distorted
cork gasket.
BMW now offers a new style gasket, Part # 11141736959, to
reduce the possibility of this problem. The new gasket is made
of a plastic-coated paper, which is colored green. Anytime a
repair or a replacement of a part is done, this new gasket
should be installed.
As of September 1989 production, the coolant chamber cover was
modified to improve the gasket contact surface by widening the
sealing lugs around the boltholes. When a new style cover is
installed on a vehicle prior to September 1989 production, make
sure that the wider bolt hole lugs on the cover do not contact
the engine block.
The old style cork gasket, Part #11141288979, is no longer
available individually. The old style cork gasket is included
in the engine block gasket set and must be replaced with the
new rubber gasket.
AERA is currently unaware of an aftermarket supplier for this
revised gasket. The AERA Technical Committee
from: Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) BMW Engine Information
Motorraum: V12 M70 Training Course Material Erich E32: Tipps & Tricks 22 30.04.2009 07:05
Motorraum: 4.0 V8 M60 vs. 5.0 V12 M70 beatnix BMW 7er, Modell E32 19 26.02.2008 22:44
Motorraum: m70 v12 läuft unrund -|MegaMan|- BMW 7er, Modell E32 17 17.01.2008 16:31
Motorraum: Änderung von M70 v12 ab 04/90? Johan735 BMW 7er, Modell E32 3 15.08.2006 21:20
Motorraum: M70 V12 in Lambo Replica Erich BMW 7er, Modell E32 6 10.02.2006 11:53
Alle Zeitangaben in WEZ +1. Es ist jetzt 13:25 Uhr.
