Alt 23.07.2025, 23:06   #17
Bevor das im internet verschwindet, hier der Text kopiert
Rear Self-Leveling Suspension Elimination Kit Installation Instructions
SAFETY WARNING: *This kit is NOT for use on vehicles with Electronic Damping Control (EDC) .
APPLICABLE TO KIT # APPLICATIONS: SLELIM KIT-E32 5 Ser. '89 thru '96
SLELIM KIT-E34M 735i/il 9/87 thru '94 ,740i/il & 750il '88 thru '94
ADDITIONAL PARTS REQUIRED FOR USE WITH ELIMINATION KIT: *Rear springs for a NON self-leveling version of the application OR a set of sport springs (Eibach, R/D, etc.) for a NON self-leveling version of the application.
*Rear shocks for a NON self-leveling version of the application
PROCEDURE: In preparation for performing this job, the vehicle must be raised and properly supported so that the rear suspension has all vehicle weight removed and is hanging freely.
1. Disconnect the hydraulic hose, at each side,running between the rear shock and the accumulator (mounted to the rear inner fender well), at the accumulator. (See Figure 1)
2. Remove the rear shock and spring assemblies including the upper mounts.
3. Use the included plugs to plug the accumulators where the hose was previously installed. Wrap the plug threads with teflon thread sealing tape before installing. (See Figure 1)
4. Disconnect the attaching lever and connecting link from the swaybar and the hydraulic regulator valve. (See Figure 2)
NOTE: Plugging the accumulators as described above, is the easiest method of capping off the hydraulic system. If you wish to remove more of the, now non-functional, hydraulic components there are a couple of options, as follows:
a) Remove the accumulators, hoses and hardware up to the regulator, leaving the regulator attached to the supply and return hoses (from the engine driven pump). Plug the outlet of the regulator. (See Figure 3)
b) Connect the supply and return hoses together in the engine compartment near the pump and remove all other hardware.
5. Assemble the new spring and shock assembly using the new hardware from the Elimination Kit. (See Figure 4)
6. Install new spring & shock assembly into the car.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://web.archive.org/web/20031106...34ElimKits.pdf
Umbau Hydraulische auf normale Heckklappe PETZ BMW 7er, Modell E38 6 06.03.2023 23:05
HiFi/Navigation: Navigation MK1 auf normale Bordcomputer mit Radio BMW 08/15 BMW 7er, Modell E38 4 16.08.2010 21:44
"normale" reifen auf trx felge supermoto-xt BMW 7er, Modell E32 5 27.02.2008 13:05
Fahrwerk: Möchte Von Niveau auf Normale Dämpfer Geht Das ? UMUT BMW 7er, Modell E32 8 20.04.2005 03:45
EDC umrüsten auf normale niveauregulierung derotsoH BMW 7er, Modell E32 23 14.07.2003 11:42
Alle Zeitangaben in WEZ +1. Es ist jetzt 03:57 Uhr.
