Alt 08.04.2008, 15:04   #8
Erlingur
Fahrzeug: E32 750 '91
Zitat von Erich Beitrag anzeigen
I do not think that the tranny problem is from tuning chips, usually only the 2 chips in the MOTRONIC are changed and the one in the EML.
But nothing on the transmission module.
Remove the heat shield below the drive shaft, then turn the rear wheel when you have lifted the car, the drive shaft will turn, and you can see marks where the drive shaft touched the tunnel above.
Either the center bearing is not pre-tensioned, not straight installed, or the tranny mounts are worn out.
I had the same problem about 2 years ago, a lot of noise under the car. In my case only the 2 bolts which hold the center bearing were lose and the center bearing was not in line.
The center bearing bracket has on each side slots (not holes) for these bolts.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.autohausaz.com/search/pro...port%20Bearing
OK, thanks.
I'll look in to this matters. Hopefully I'll find an solution.
Soon I'll post some pics here of my M70 baby
Erlingur ist offline   Antwort Mit Zitat antworten
Motorraum: Transmission Fundamentals Erich 7er, allgemein: Tipps & Tricks 2 01.05.2009 18:45
Elektrik: Electric and transmission petoch BMW 7er, Modell E32 5 13.04.2008 04:57
Bremsen: Manual transmission braveheart BMW 7er, Modell E32 1 02.04.2006 23:16
I Need A Transmission For Bmw E32 braveheart Suche... 2 17.03.2006 21:08
Motorraum: rough idle & shimmy-the ultimate guide Erich E32: Tipps & Tricks 0 23.11.2005 08:50
Alle Zeitangaben in WEZ +1. Es ist jetzt 19:55 Uhr.
