05.05.2007, 16:34
I tried initializing keys- no luck
Im gonna test with leaving key in position 1 for a couple of min
Battery is full
I be back
05.05.2007, 17:16
Had key in car for 20 min, the PPPP did not reset
Im going mad :(
05.05.2007, 19:58
Mitglied BMW7er-Club
You say, Your battery has 12 V deffinately? ok.
Try this: Loosen both Battery cables and put "+" and "-" together for 20 Seconds. Then refasten them, Your car should be totally reset.
I have no other idea anymore - except: Did u check the fuses under the rear seat? There maybe some more fuses in the black box, which u must open (there are 3 screws as far as I remember).
Greets Norbert
06.05.2007, 22:37
My car runs great now!
Thanks for all your help guys! You rock
It turned out that a fuse for the OBC was broken, it looke allright but at a closer look you could see that it was broke.
I had to re-initialize the key
So much problems and headache cos of a faulty fuse
Thanks guys
07.05.2007, 09:16
Well, at least: Happy end!
Have fun with Your Beamer!
Greets Crazy
