Alt 01.11.2005, 13:28   #1
jarmo_
Standard Gear box not working
Hello from finland!
I just bought me a 730ia -89, and the gear box is not working very well.
It kind of jumps from first gear to the 3rd gear.
Even if i try to lock it on the second gear, it doesn`t change from 1st gear at all. Otherwise gear box is working propely. I changed the oils, it was ok. No smelly and colour was red.
It is like there is no second gear at all.
I am thinking of starting to change the gear box, but i can not find it from Finland, is there any good scrap yard near Rostock where i could find one?
Or if somebody has this kind of gear box to sell, my friend is coming next week to germany and he could take it with him.
In my car has a ZF4hp22 gear box, however, bmw vin decoder tells me that there should be ZF4hp22/eh?
Still,it seems that gear box is this cars original.
So, if some one knows what is wrong with my gear box or has a Zf4hp22 gear box to sell, please contact me by privat messages.
ps. sorry about my poor english.
Jarmo
jarmo_ ist offline   Antwort Mit Zitat antworten
Alt 01.11.2005, 13:58   #2
If there is a used parts dealer near Rotsock, I do not know. But I will list some for you, they can also ship it to Finland.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.gebrauchtee32teile.de
This is Hendrik. He is wellknown here and he also speaks English. So send him an email.
BMW Gebrauchtteile Hamburg
Helmuts BMW Teile Shop
And this one sells reconditioned transmissions with 6-12 months warranty.
Was recommended as trustful on several boards. Price is very reasonable.
Very IMPORTANT: Make a picture of the name plate of the transmission. On the block might be a different name. But the plate shows the exact number of the transmission.
AND!!!!!!
Check if the connection on the trans box to the control has 7 or 8 cables!!! VERY IMPORTANT. Here a pic from my trans with the plate so that you can see where to look for the plate.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://tridem.han-solo.net/auto/erich/friends/f.jpg
Some more info here
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://shrubbery.student.utwente.nl/...rbox_swap.html
Alt 01.11.2005, 15:45   #3
Crazy
Mitglied BMW7er-Club
Benutzerbild von Crazy
Fahrzeug: leider z.Zt. keinen 7er
Hi jarmo,
first we have to check, if Your car is from early 1989 or later. The reason is, the first 730i only had a mechanical transmission, without EH-switch.
This is the switch in the console left of the gear lever with the position points S-E-M. Both transmission versions are 4HP22 but the electronic one has additionally "EH".
I know that problem from my 1987 730i, which does that from 2nd to 4th gear - sometimes seems as if there is no 3rd between - but only if car is warm.
If You have the EH-Switch, just try to switch gears manually ("M"), if not - hmmm...then try oil change with filter first.
Greets Norbert
Crazy ist offline   Antwort Mit Zitat antworten
Alt 02.11.2005, 07:55   #4
jarmo_
There is no s,e,m switch in my car, and it is zf4hp22 without EH.
My car does not change gears at all when it is cold.
I did change oils and filter too, no inprovement.
Thanks for you reply and if you have any more ideas what could be wrong plese let me know..
And if i replace this ZF4hp22 => ZF4hp22/EH, how much work there is?
These ZF4hp22/EH gear boxes i can find in finland.
Jarmo.
Geändert von jarmo_ (02.11.2005 um 08:19 Uhr).
Alt 02.11.2005, 13:32   #5
Crazy
For change from non-EH to EH You need
- the gear box
- the electronic box (is behind the loudspeaker on the right side)
- the switch and the console where it fits in
The cable should be there, its in my 1987 one, too.
For I never tried that, others can post ideas, I think something has to be connected to the motor's electronic, too.
Greets Crazy
Alt 03.11.2005, 08:02   #6
jarmo_
I checked the plate and the electric connector.
It says ZF 4hp22, and there was only 2 pins on the connector.
The connector was backwards from the plate about 10 cm, is it the right one?
Alt 03.11.2005, 08:33   #7
Crazy
Where did You find a 2-pin-connector? On the gear box? If so, its the mechanical one, as You said.
Greets Crazy
Alt 03.11.2005, 08:52   #8
jarmo_
Yes, on the gear box.
Is it possible for you to find me a box like that from those scrap yards in germany, for me it is a bit difficult because of the language.
I would be very grateful for your help...
Jarmo
Alt 03.11.2005, 14:49   #9
Crazy
You can try to get those from ebay.de, thats where i would buy one.
I know, this guy has not only one gear box.
Greets Crazy
Oel-Analyse Erich BMW 7er, allgemein 2 09.02.2004 18:51
Reparatur Anleitung Verlag Bucheli (so Schlecht!!!!) arc_master BMW 7er, Modell E32 17 29.11.2003 16:44
Alle Zeitangaben in WEZ +1. Es ist jetzt 17:29 Uhr.
