Alt 17.12.2024, 01:38   #36
ueber 30 Jahre zu spaet finde ich diese TI, das haette mir BMW ja alles kostenlos ausbauen + das verstaerkte Teil einbauen muessen
Mittlerweile hab ich das selber repariert
SIB 64 01 89 IHKA - Stepper Motor Bracket Breakage 1989-10-01 GROUP 64 Heating & Air Conditioning B 64 01 89 Woodcliff Lake, NJ Technical Dept October 1989
This bulletin supersedes S.I. 64 01 89 (1814) dated February 1989. Additional repair information and warranty information have been added.
Please remove and discard S.I. 64 01 89 (1814) dated February 1989 from your S.I. binder.
SUBJECT: IHKA - Stepper Motor Bracket Breakage MODEL: E32
Situation: You may receive a complaint from a customer that he is unable to regulate the temperature out of the center dash vents or that cold air blows out of one side and hot air out of the other.
This may be caused by a broken stepper motor bracket for one of the two center dash vent stepper motors.
Diagnostic Hint: As the motors can still operate no faults will be logged in the IHKA Control Unit. Removal of the radio allows for visual inspection of these brackets.
Repair Procedure: Replace the center housing portion (P/N 64111374325) of the IHKA assembly. Removal of the IHKA assembly is required. Follow the procedures given in the workshop manual (Group 64) for its removal.
Note: Grease running out of the vent flap stepper motors can cause the plastic mounting area to become brittle, thereby increasing the possibility of the mounting area to break. Stepper motors with the manufacturing dates of 752 or higher have been improved to prevent this from occuring.
Inspect the two vent flap stepper motors. If the production date (stamped next to the electrical connector) is 751 or lower, replace the motor.
Warranty Information: Covered under the terms of the BMW New Car Limited Warranty of 3 Years/36,000 Miles. Defect code: 64 11 40 29 00
Labor operation: 64 11 200 - Remove and reinstall lHKA housing , Labor allowance: 65 FRU - 735i, 7351
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://bmwrepairguide.com/sib/640189.pdf
das wichtigste uebersetzt
Situation: Sie erhalten möglicherweise eine Beschwerde von einem Kunden, dass er die Temperatur aus den Lüftungsschlitzen im mittleren Armaturenbrett nicht regulieren kann oder dass auf der einen Seite kalte Luft und auf der anderen Seite warme Luft herausströmt. Dies kann durch eine defekte Schrittmotorhalterung für einen der beiden Schrittmotoren der Lüftungsschlitze im mittleren Armaturenbrett verursacht werden.
Diagnosehinweis: Da die Motoren weiterhin funktionieren, werden keine Fehler in der IHKA-Steuereinheit protokolliert. Durch Entfernen des Radios können diese Halterungen visuell überprüft werden.
Reparaturverfahren: Ersetzen Sie den mittleren Gehäuseteil Teilenummer 64111374325 der IHKA-Baugruppe. Das Entfernen der IHKA-Baugruppe ist erforderlich. Befolgen Sie zum Entfernen die im Werkstatthandbuch (Gruppe 64) angegebenen Verfahren.
Hinweis: Aus den Schrittmotoren der Lüftungsklappen austretendes Fett kann dazu führen, dass der Kunststoffmontagebereich spröde wird, wodurch die Wahrscheinlichkeit eines Bruchs des Montagebereichs steigt. Schrittmotoren mit Herstellungsdatum 752 oder höher wurden verbessert, um dies zu verhindern. Überprüfen Sie die beiden Schrittmotoren der Entlüftungsklappen. Wenn das Produktionsdatum (auf dem elektrischen Anschluss eingestanzt) 751 oder früher ist, ersetzen Sie den Motor.
da viele Links nicht mehr gehn, hier einige updates
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://www.shiftbmw.com/model/e32/center-vents/
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://www.shiftbmw.com/model/e32/i...ts-and-system/
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://www.shiftbmw.com/model/e32/m...ement-e32-e34/
Steuerklappen Heizung von rofra11 Robert Interner Link) https://www.7-forum.com/forum/showthread.html?t=150925
Geändert von Erich (17.12.2024 um 03:44 Uhr).
Heizung Steuerklappen rofra11 E32: Tipps & Tricks 4 06.08.2024 22:43
Heizung/Klima: Verständnisfrage IHKA kyrbys BMW 7er, Modell E32 4 23.07.2010 16:59
E32-Teile: IHKA Steuergerät marco916 Biete... 1 10.12.2009 18:05
Elektrik: kriechstrom ihka? ratbaron BMW 7er, Modell E32 1 03.08.2009 22:05
Steuergerät IHKA Eduard17 Suche... 2 29.04.2006 08:55
Alle Zeitangaben in WEZ +1. Es ist jetzt 07:47 Uhr.
