die passen auch fuer den M70, sind die mit den 4 Loechern: Bosch Gen IV fuel injectors Bosch, BMW, M10, M20, M50, M52, M70, M73
New Bosch Gen IV: 0280158034S, Old Bosch/Lucas: 0280150715, D3762
Performance upgrade Generation III Bosch fuel injectors - 4-hole fuel nozzle, LIFE EXPECTANCY: More than 150,000 miles, Compatible with all OEM sensors, injector drivers/controller ECUs. No remapping or resetting of any OEM parameters, Double-slotted for fuel rail retainers, 4-hole Disc Fuel Nozzle - BEST fuel atomization
BENEFITS OF GENERATION 3 BOSCH FUEL INJECTORS: This set of Bosch fuel injectors is not the manufacturer's original equipment (OEM) spec injectors for this vehicle. These fuel injectors have been carefully tested and cross referenced to match the internal coil resistance and are compatible with your stock ECU. Use for stock replacement OEM original equipment
https://www.fiveomotorsport.com/0280...0-m20-m70-m73/
