Alt 05.02.2018, 20:33   #15
Beumers
Fahrzeug: E32-735i dec 1986
Hallo Erich und Marcus.
Yesterday I was able to check for 12 v at pin 1 of the watervalve connector in the car.
Ignitionkey al the way to the right. Control unit on the dashboard switch on auto. No 12 volts.
If I read the electrical manual the right way the 12volt connection goes right trough fuse 33 to the control unit on the dash where it goes via switch auto directly to pin 1 for both the valves. The negative contact goes trough the control unit behind the sword to each valve separately.
It's the same way it is described in the pdf "klimaautomatik". I checked the electrical manual to be sure. (It would be very helpfull if everybody used the same description for the parts and units.)
For now I can rule out das Steuergerät I think. So first I have to find out why there is no 12volts on pin 1. Thanks for pointing that out again Marcus.
Now I have to wait untill I can go back to the car in the storage.
Keep you posted if I can.
Regards Henk.
Beumers ist offline   Antwort Mit Zitat antworten
engl. Auto: Jaguar X-Type The Stig Autos allgemein 26 25.01.2014 18:38
BMW-Individual: BMW Type ? danyboy73 BMW 7er, Modell F01/F02 22 12.07.2011 00:50
Type auf dem Nummernschild ..? Silent-Mike BMW 7er, allgemein 90 22.08.2010 20:48
Type des Automatiköls gesucht -Anubis- BMW 7er, Modell E32 7 24.08.2009 16:30
750i ..VS.. S-type tim750i BMW 7er, Modell E38 26 31.05.2006 12:22
Alle Zeitangaben in WEZ +1. Es ist jetzt 02:17 Uhr.
