wer seinen OBC reparieren will, auf BF hat einer den auseinander genommen + folgende Teile/Elkos gefunden, die getauscht werden muessen:
My OBC was acting up, it would not let me set the time and whenever I pressed one of the number buttons it would act as if I had pressed the range or timer button, not letting me input any numbers. I haven't seen a single post if there were capacitors or not in the OBC, so I took mine apart. I found 6 capacitors, one which was leaking very badly. All measurements are approximate, eyeballed with a ruler. The list is as follows:
220uf 50v x1 (10mm wide 16mm tall)
10uf 50v x1 (6mm wide, 8mm tall)
10uf 35v x2 (5mm wide, 11mm tall)
330uf 6.3v x1 (10mm wide, 13mm tall)
10uf 16v (3mm wide, 7mm tall) - this one was leaking the most.
Here are some pictures.
 https://www.bimmerforums.com/forum/s...itor-List-Pics
