Alt 11.08.2009, 12:42   #1
wenn das immer noch auftritt, tippe ich ganz stark auf den Neigungsalarmgeber = NAG:
SUBJECT: Anti-Theft System (DWA) False Alarm caused by Inclination Sensor (NAG)
MODEL: 5 Series (E34, E39), 7 Series (E32, E38), 8 Series (E31)
Situation: The Anti-Theft System (DWA) may sporadically trigger false alarms under two specific circumstances, as follows:
(A) Approximately 30 seconds after arming DWA
(B) Sporadically, usually at the same parking location
Cause: (A) Mechanical reverberation of the inclination sensor (NAG).
If a door on the vehicle is slammed shut, the mounting of the inclination sensor (NAG) can vibrate. If the alarm is now armed while the sensor is still vibrating, the DWA Control Module stores a random reference position. After the normal delay of approximately 30 seconds, the
DWA Control Module evaluates the signal from the NAG (which has now quit vibrating) and detects a change of position. This now triggers the alarm.
(B) External electromagnetic radiation that acts on the inclination sensor.
Note:
In both cases, the alarm counter will store the "inclination sensor" as the location that triggered the alarm.
Vehicles Affected: 5 Series (E34, E39), 7 Series (E32, E38), 8 Series (E31) - vehicles equipped with DWA and produced prior to July 1996.
Correction: In the event of customer complaint (only affected vehicles equipped with DWA), proceed as
follows:
1. Connect the DIS Tester to the vehicle.
2. E38, E39 vehicles: Under "Body Electronics", select "ZKE" (Central Body Electronics) and then "Anti-Theft Alarm".
E31, E32, E34 vehicles: Select "18 Burglar Alarm System".
3. Select "Service Functions".
4. Select "DWA Alarm Counter".
5. If the majority of entries are for the inclination sensor, identify the index number of the sensor itself (index number is printed on the label of the sensor).
The NAG is mounted on the left- or right-hand side of the luggage compartment, depending on the model. Refer to the appropriate Electrical Troubleshooting Manual (Component Location).
6. If the inclination sensor (NAG) bears an index number of 10 or lower, it must be replaced with an NAG bearing an index number of 11 or higher.
Note: Depending on the equipment level of the vehicle, the NAG may be mounted behind various accessories such as CD Changer, Cellular Phone Transceiver, etc.
Lagebild:
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://members.roadfly.org/smoothy/False%20Alarm.pdf
Alt 11.08.2009, 12:54   #2
snes
V12 Fanatiker
Benutzerbild von snes
Fahrzeug: E38 750i , Mercedes GLS 350, Mercedes SL 320 R129, Lincoln Town Car, Lincoln Continental
wenn ich die DWA abstecke funktioniert dann noch alles? (bis auf den BC natürlich)
snes ist offline   Antwort Mit Zitat antworten
Alt 11.08.2009, 13:28   #3
peter becker
750i powered by ROTTALER2
Benutzerbild von peter becker
Das ist schwierig zu testen, wie gesagt, bei eingeschalteter DWA, sehr
warmen Ausentemperaturen und leichter Schrägstellung des Auto ( vor
der Garage) macht er diesen Fehler,aaaaaber, sehr sporadisch..... ich müsste
ihn quasi viele Tage vor die Garage fahren, hoffen dass es richtig warm wird
und die DWA ausgeschaltet lassen.....dann kööööönnte ich davon ausgehen,das es der Sensor ist, wenn sich in der Zeit nix tut...........
Viele Grüsse
Peter
Alt 11.08.2009, 13:43   #4
ist ganz einfach festzustellen, wie oben angegeben
1. durch Diagnose und Fehlermeldung
2. Die Teilnummer mal ueberpruefen, die an dem Teil ist:
Geändert von Erich (11.08.2009 um 13:51 Uhr).
Alt 11.08.2009, 13:46   #5
peter becker
Ja Danke Erich, dann werde ich das mal in meine TO DO Liste aufnehmen.
Viele Grüsse
Peter
Elektrik: Ist das bei der DWA normal? Stiefelknecht BMW 7er, Modell E32 1 17.04.2008 16:50
DWA und die Blinkeransteuerung peter becker BMW 7er, Modell E32 5 06.03.2008 16:50
Elektrik: Welche DWA ist die Nummer 302a? Stiefelknecht BMW 7er, Modell E32 1 10.11.2007 14:11
Was ist das für eine DWA? Domi BMW 7er, Modell E32 8 30.06.2006 17:51
Wie funktioniert die DWA? meschanescha BMW 7er, Modell E38 3 30.09.2003 20:22
Alle Zeitangaben in WEZ +1. Es ist jetzt 18:33 Uhr.
