Alt 26.04.2009, 12:08   #1
CHF 202 ist nichts fuer unsere E32, hier mal kopiert:
CHF 7.1, CHF11S, and CHF202 are are high performance hydraulic fluids formulated for central hydraulic systems such as power steering, rear axle steering, level control, hydro-pneumatic suspension, and shock absorbers.
Pentosin Hydraulic Fluids are ideal for cold weather climates, and also perform exceptionally well under extreme temperature changes, with an operating temperature range from -40º F to +275º F
CHF 7.1 is a mineral oil based fluid; CHF11S and CHF202 are synthetic oil based fluids. CHF 7.1 fluid is green in color, and CHF11S and CHF202 are dark green in color. Available in a 1 liter bottle (1.06 quarts).
Pentosin hydraulic fluids are suitable for the following applications:
CHF 7.1: Audi/Volkswagen (1984-1989)
BMW (1987-9/1991)
Volvo (1995-1998)
CHF11S: Audi (1990-2006) TL52 146.00
BMW (9/1991 on); all beginning with model E32
Chrysler Crossfire 05127381AA
Dodge Sprinter (all years)
Mercedes-Benz (staggered S-class models from 1996 on)
Mini (2002 on)
Nissan (1994 on)
Porsche (1995 on)
Rolls Royce
Saab 900 coupe (95 on); 900/9000
(97-98); 9-5 (98 on)
Volkswagen (1990-2006) TL52 146.00
Volvo (3/1998 on)
CHF202: Audi (2006 on) TL52 146.01
Porsche Cayenne (2005 on)
Saab (2006 on)
Volkswagen (2006 on) TL52 146.01
Volvo (2002 on)
Important note on fluid compatibility: if vehicle specifications state CHF7.1, CHF11S and CHF202 can be substituted in place of, but not mixed with, CHF7.1. If vehicle specifications state CHF11S (or CHF202), do not substitute with CHF7.1. CHF11S and CHF202 are fully compatible and mixable. Pentosin CHF fluids should not be mixed with ATF fluids. Always check your owner's manual to confirm the correct fluid is being used for the vehicle.
Alt 26.04.2009, 21:29   #2
McTube
Benutzerbild von McTube
Fahrzeug: S50B32
Ich tippe mal im Lotto und vermute die werden LHM+ angeben, ist mineralisch, mit älteren Spezifikationen mischbar (weil mineralisch...) und entspricht "B71" -> 7.1???
Grüsse
Michael
Alt 26.04.2009, 21:43   #3
Schorsch
BastardOperatorFromHell
Benutzerbild von Schorsch
ich hab das LM jetzt schon fast ein jahr drin - bisher keinerlei probleme mit schläuchen oder der pumpe. alles nach wie vor schön.
kann also bedenkenlos eingesetzt werden.
Alt 27.04.2009, 08:17   #4
peter becker
750i powered by ROTTALER2
Benutzerbild von peter becker
Hier die Antwort auf meine Anfrage........................
Sehr geehrter Herr Becker,
es ist in der Tat so, dass nur noch begrenzte Mengen dieses Produktes hergestellt werden können. Diese Mengen sind für BMW-Händler reserviert, so dass Sie das Pentosin CHF 7.1 in jeder BMW-Werkstatt erhalten werden.
mit freundlichen Grüßen / kind regards
Deutsche-Pentosin Werke
Deutsche Pentosin-Werke GmbH
Industriestraße 39-43
D-22880 Wedel
Tel.: +49 4103 9134 0
Fax: +49 4103 9134 71
email: info@pentosin.com
Geschäftsführender Gesellschafter / CEO & Shareholder: Jürgen Niemax
Amtsgericht / Local Court: Pinneberg HRB 1556
USt-Id-Nr / VAT-Id-No: DE 134 796 898
Steuer-Nr / Tax No: 1829601292
Viele Grüsse
Peter
Alt 27.04.2009, 09:29   #5
Danke fuer die Anfrage da, Peter.
Das Febi ist billiger als Pentosin, also kein Problem.
Gibt es z B bei Stahlgruber, oder hier
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) autoteile.cc
und glaub ich auch bei A.T.*
denn das selbe Zeug wird ja auch in Seat, Audi und VW benutzt, und die armen Porsche und RR Besitzer kaufen da auch ein.
nur aufpassen, FEBI hat auch 2, einmal fuer CHF 7.1 =
M(0)6161 und das andere fuer CHF 11S = S(0)6162
Und das ist die Info und Zusammenstellung von den Audi 100 fans dazu
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Audi100.Selbst-Doku.de : Main - Grünes Gold
Alt 27.04.2009, 11:24   #6
peter becker
Tjaaaaa, das Febi (0)6162 hat mir mein Teilehändler damals als 7.1 Ersatz
verkauft... also nicht!!!! das (0) 6161, was nach Deiner Auflistung das
richtige wäre.......
Viele Grüsse
Peter
Alt 27.04.2009, 11:41   #7
M = Mineralisch
S= Synthetisch
daran siehst Du schon was das richtige ist.
Alt 27.04.2009, 12:55   #8
McTube
Fahrzeug: S50B32
Viele Grüsse
Peter
Da hat Erich sich vertippt, an anderer Stelle behauptet ein gewisser Shogun folgendes:
also: S6161
Made by Febi/Bilstein. Same specifications as Pentosin brand 11s fluid. Heat Range -40c/+130c. Made in Germany. 1 liter container. Please note: Check Reservoir For Proper Fluid Type
Made by Febi/Bilstein. Same specifications as Pentosin brand 7.1s fluid. M6162. Heat Range -40C / +100C. Made in Germany. Please note: Check Reservoir For Proper Fluid Type
Grüsse
Michael
Pentosin CHF 7.1 Ersatz alphornblaeser BMW 7er, Modell E32 12 05.09.2006 10:32
Lenkung: Pentosin siebenerfan66 BMW 7er, Modell E32 3 28.10.2004 18:48
MOLY-PREMIUM Gleitflächenversiegelung OnlyTheFinest Fahrzeugpflege 61 10.06.2004 06:35
Innenraum: Ersatz fuer BMW Business RDS (C23) spynick BMW 7er, Modell E38 0 02.06.2004 22:12
Pentosin Ersatz gefunden Erich BMW 7er, allgemein 6 07.02.2004 04:59
Alle Zeitangaben in WEZ +1. Es ist jetzt 14:30 Uhr.
